Thread: Splash pool
    Apr 2016
    Rome/Ga
    2
    Splash pool
    Are there any splash pool owners on this forum? I am looking for a new pool cleaner but not the type that came with the splash Superpool. I don't know if any other will work on my pool. I also would like to abb a fountain to the pool.I have had this pool for years and no problems.
    Splash Superpool 17x30 has been a saltwater pool for years. Power flow Matrix by Hayward 1.5 hp new ordered 4/25/16 from Amazon.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Splash pool
    Any small suction side cleaner designed for above ground pools will work. It's only a matter of your pumping system to be able to provide enough suction to the unit, assuming you're going with a suction cleaner like the Pentair AutoVac that comes standard as an accessory for Splash Superpools. Is there a reason you don't like the AutoVac? If there is, likely some of the options from Hayward would work for your pool as well. See them here: Cleaners | Above Ground Pool Cleaners - Hayward Pool Products Pentair also has the Kreepy Krauly which is a different style cleaner than the AutoVac.
    Isolated Spa - 345 Gallons
