Thread: 2speedpump
    Apr 2016
    Toledo
    1
    2speedpump
    2 speed motor runs on low speed turn it to high speed and runs for 3 seconds and shuts down can not get it to run on high speed for more than 3 seconds
    Sep 2013
    Charleston, SC
    537
    Re: 2speedpump
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: 2speedpump
    Welcome to TFP!
    Are you in Oregon or Spain? Edit your profile to add your state or country to your location so it shows up over there <-----, climate is important when we are helping you with your pool. Tell us more about your pool and equipment by adding the info to your signature, more here, Pool School - Read This Before You Post
    Is it new?
    Has it ever worked properly?
    Shut down? Kicked breaker? Thermal shut off? Is it hot?
    It runs fine on low?
    What is the filter pressure when clean? And now?
    Any bearing noise?
    Is it hot when running on low?
