Thread: What is this for?
    Johnmarkpainter's Avatar
    Apr 2016
    Hendersonville, TN
    55
    What is this for?
    I just moved into this house/pool.
    This was sitting on the deck next to the pool.
    Any theories on what it's for?
    I'm guessing it is related to the pool cover.
    It is made from particle board...not the most water resistant material
    The pool wasn't closed this winter.
    28,000 Gallon, IG, Vinyl, SWG, Sand Filter
    Goldline Aqua Rite SWG
    Hayward Pro Series Sand Filter
    Flotec Pump
    Hayward Turbulent Flo Chamber
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: What is this for?
    I suspect it was a float to keep the center of the cover from sagging into the water. You're looking at it upside down.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I suspect Richard is right, even if my first thought was a floating table to hold drinks in the pool.
    Isolated Spa - 345 Gallons
    May 2013
    Ontario, Canada
    63
    Looks like something I wouldn't want in my vinyl pool!
    18' x 36' vinyl steel wall pool with deep end, 2 lights and 6' steps, main drain, SWG, Cartridge Filter, 320,000 BTU Rheem heater, 3/4HP 1 stage pump - Ontario, Canada
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    I like JVs idea though.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Apr 2016
    Hendersonville, TN
    55
    Makes sense...THANKS
    And the idea of that stuff disintegrating into the water seems like a bad move.
    I'll be researching before next winter as to whether we will close the pool.
    An old local pool company here said their customers are about 50/50 on just keeping them open all winter.
    Flotec Pump
