Thread: Replacing a pump motor, what else do I need?
    Sep 2008
    Toronto, Ontario, Canada
    52
    I'm pretty much decided to buy a A.O.Smith/Century variable speed replacement motor to replace my Hayward Superpump single speed. Since my Superpump is 1hp, I've been recommended the ECM16CU rather than the ECM27CU which is 2.7 hp.
    Looks like both pumps come bare bones so I'm wondering what else I need to mount it to my Superpump housing. Assuming the wet end is in good shape, can I just reuse the seals? What other parts do I need?
    In the attached diagram, I assume I'm just getting part #20. Are there other parts I should order at the same time?
    Concrete (gunite) inground pool and spa (17,000 gallons)
    Hayward H350 natural gas heater (electronic)
    Goldline Aquarite chlorine generator
    Hayward pumps, Hayward Pro Series sand filter, Goldline valve actuators
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Replacing a pump motor, what else do I need?
    You need part 23.
    Sep 2008
    52
    Excellent thank you.
