Thread: deck on above ground pool
    May 2014
    amsterdam ohio
    26
    Planning on building a deck around my aboveground pool and I was wondering about the composite decking. I understand that it can get warm but is it tolerable? Does it scratch easily? How does a saltwater system affect it? Is it slippery when wet? And all the pros and cons that you could help me out with. Thanks
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: deck on above ground pool
    I have built around 1000 sf of deck using Choicedek from Lowes. It is great stuff. If it has any cons I haven't run into them yet.
    Made in US
    Not too hot
    Not slippery
    Easy to work with
    Made with mostly recycled stuff
    Can be installed with hidden fasteners
