Thread: Low speed enough to run SWG?
    I'm looking at replacing my current 1 speed pump with this 2 speed: A.O. Smith 1 H.P Square Flange Dual Speed Up Rate Motor - UQS1102R - INYOPools.com
    My concern is having enough power at the low speed setting (1/6 hp) to run my SWG. The requirement is a minimum of 20 GPM. My equipment pad is less that five feet above the height of the water. Is there an easy way to figure out whether this pump would be sufficient?
    33K gal L-shaped (2008) IG vinyl | AutoPilot Digital SC60 SWG | 1 HP Sta-Rite Dura-Glass pump (model P2RA5E-181L) | 300 sqft Sta-Rite cartridge filter (model S7M120) | Dolphin Sprite cleaning robot | Merlin Smart Mesh winter cover
    South-Central PA
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Low speed enough to run SWG?
    This would depend on the amount of head (or resistance) in your current plumbing configuration. If you look at this performance curve, your motor would be the B and G curves, assuming that the Pentair 1 HP, 230V, 2-speed Whisperflo that uses this same motor is equivalent.
    I'm not sure of a good way to determine your feet of head directly... but as long as you had less than ~20 feet of head in the system, it would be over 20 gpm at low speed, unless I am mistaken.
    Isolated Spa - 345 Gallons
    mas985's Avatar
    Pleasanton, CA
    11,737
    It should not be an issue unless you have a lot of head loss in the plumbing. What was the clean filter pressure?
    Mark
    Quote Originally Posted by JVTrain View Post
    JVTrain, I have tried to read/understand the process of determining feet of head, but am still confused. How is this determined?
    Quote Originally Posted by mas985 View Post
    mas985, my normal clean pressure is around 11 psi.
    South-Central PA
    mas985's Avatar
    Pleasanton, CA
    11,737
    It doesn't seem like your plumbing is overly restrictive so it shouldn't be a problem.
    As for determining head loss, there are a couple different methods I use and I have a couple tools in my signature that helps with that but I don't think you need to go to the trouble. 20 GPM on the above head curves is very restrictive and I don't think I have seen a pool yet with that restrictive of plumbing.
    Mark
