Results 1 to 16 of 16
Thread: Question on Stenner system placement
    Mar 2013
    CT
    349
    I am doing some research on going the Stenner route for chlorinating my pool.
    I'm leaning towards the complete set up that's already assembled.
    Looks like this:
    I have zero room on the exterior of my house near my filter/pool pump to place this assembly. I have a bulkhead door on one side and the corner of the house on the other side. So, I was thinking I would put the pump/tank assembly in the basement and drill a hole through the exterior wall for the chlorinating tube to exit. The assembly will be a few feet BELOW my pump and filter plumbing - since it will be in the basement - it's obviously below ground level. This will also keep the chlorine cool and out of the sun.
    Does anyone see a problem with placing the system below the level of my pool plumbing? I'm just thinking from a pumping efficiency standpoint since the pump will need to send the chlorine up a few feet to get discharged into the pool plumbing.
    Maybe I'm worrying for nothing but I just wanted to throw it out there for some opinions.
    Thanks!
    Dan
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Apr 2015
    South Central PA
    297
    Re: Question on Stenner system placement
    I don' know about the height difference, but the kit is far more expensive than ordering the parts from Locke Well and Pump or other online vendors, and most likely the kit would be shipped unassembled anyways....the assembly is nothing really- a few bolts.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    I don't know what the head pressure would be but with the small tubing I would not think it would be much. I would just make sure you have a quality check valve at your injection site above the stenner. If the tubing failed you don't want to siphon your pool into your basement. Who are you looking at getting it from. It has been mentioned that their are places that you can get the whole kit part by part. I can tell you this. It will not be shipped as the picture. You will have to put it together but it's only a few bolts.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Mar 2013
    CT
    349
    I was looking on line at Cannon Water Technology. The entire thing is $425 shipped.
    Locke works out to $400 shipped.
    Aug 2014
    Austin, TX
    74
    If you get the high pressure pump, I doubt you would have any issue with the elevation change. Like mentioned above, you would have to monitor it as a leak in the pump tube/discharge line could cause your pool to leak into your basement if the check valve malfunctioned. I would recommend changing the pump tube at least annually. That would also give you a test of your check valve since you would need to disconnect the discharge line to replace the pump tube.
    I purchased mine from Cannon Water, the complete kit (45MPHP10 with 15gal tank) and it shipped completely assembled with the suction line/strainer installed and the pump mounted with rain roof installed. There were 4 screws that were installed for shipping protection only that you need to remove so the pump is removable from it's mount, but otherwise it was assembled. If you can find the components (tank, pump, rain roof, pump mounting bracket) cheaper, it really would be simple to assemble yourself.
    12300gal IG PebbleTec w/7' raised Spa & Waterfall. Built Aug 2015
    Pentair IntelliFlo VS Pump, Pentair 420 Cartridge Filter, Ultra UV, Auto Fill
    EasyTouch control w/ Remote, Infloor Cleaner w/1.5HP Pump and Leaf Canister
    Stenner 45MPHP10 w/15gal tank, Rainbow 320 Chlorinator, TF-100 Test Kit.
    JoyfulNoise's Avatar
    May 2015
    13,191
    Does the area of your basement have adequate ventilation? Bleach vapors are not as noxious as acid vapors but they can build up in a poorly ventilated area and cause corrosion issues. You could wind up having the basement smell like a laundromat.
    You can separate the motor from the tank and have the motor wall mounted near the equipment pad and locate the bleach tank further away. One member here on TFP is actually going to bury his bleach tank (a 55 gal food grade drum) in the ground.
    Matt
    Mar 2013
    CT
    349
    I spoke to someone at Lockwell Pump and he said this was not recommended because the pump would fail prematurely...so there goes that idea.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Quote Originally Posted by dschribs View Post
    It would not be the pump that would fail. The pump sees no liquid. What would fail would be the tube between the rollers that really should be changed out yearly anyway. You may have an issue but your millage may vary. What Lockwell was getting at is once the pump turns off normally you would not have pressure on the injection side. The check valve would prevent that but your dealing with head pressure or gravity. I would not think it would be that much but that's your call. You said you do not have room at the pad. Do you have room for the pump and timed power at the pad. Sink a 4x6 at the pad and mount the pump on it. It can take the weather. You could run the suction side in conduit to the basement. That route I would run two pickup tubes from the tank to the pump. One to use and one as spare for a leak or clog. If not I would at least keep a pull string with the pickup tube.
    Mar 2013
    CT
    349
    Thats not a bad idea. Can you explain what you mean by two pick up tubes and pull string???
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    I am from the school of thought if it's made by man it can and will break at some time. Say you buried your conduit and its 40' long with several bends. If you have room pull two. If and when you have a problem just switch to the other tube. No room for two pull the tube with a nylon pull sting also. This also does not need to be water tight at the pad. 90 up at the 4x6 with long radius would be best. Come up even to the top of where the pump will be then. The conduit will be open to rain and that's bad. A fix will be two 90's to make a U. Now it pointing down and less likely to get direct water in the conduit and down to the basement. You could even give it a dollop of silicone to seal it. I would glue all the other joints except for the "U" at the end.
    JayG's Avatar
    Aug 2015
    Harrison, NY
    189
    If you are price sensitive, purchase a used food-grade HDPE tank locally...especially if you decide to mount the Stenner independently from the tank. Look on Craigs list. They can be had for ~$20 for the smaller (35 gal) version to $35 for the 55 gal version. As Matt mentioned, I am the nut who buried his 55 gallon tank adjacent to my equipment pad. I think I paid $35 for mine. Paid my gardener to dig the hole and then put gravel and sand underneath and around the sides. I also surrounded the upper part of the tank with rigid foam to help shield the tank from the warmest part of the ground. Then built a cover for it. So far, it is working out great. I've now filled the tank and the overall LC temperature has remained ~54F. Low enough that degradation over 3 months should be minimal.
    Jay--Metro NYC
    35K gal, in-ground, free-form, pebble finish, 2 skimmers, 3 returns, autofill. No spa, no features. Partial shade.
    Pentair C&C cartridge filter (400 sq in), Pentair VS pump, Pentair 140 btu heat pump, Triton Plus Robo-cleaner; Stenner with 55 gal bleach cistern. TFT 100 test kit.
    Mar 2013
    CT
    349
    fauxQ
    No issues w your pump pulling the bleach given that the pick up is located so far below the pump itself??
    JayG's Avatar
    Aug 2015
    Harrison, NY
    189
    fauxQ
    Sent from my SM-G935V using Tapatalk
    I don't anticipate any problems. The bottom of the tank is only ~32" deeper than ground level.
    Jay--Metro NYC
    Mar 2013
    CT
    349
    Good to know. Thats about where I will be w my barrel in the basement.
    JayG's Avatar
    Aug 2015
    Harrison, NY
    189
    Update: I finally got all the parts to hook my Stenner to my cistern and pulling LC from the barrel was no problem. It took a while to prime, but once that was accomplished, the flow rate was spot on.
    Jay--Metro NYC
    Mar 2013
    CT
    349
    Perfect!
