Thread: Drain to replace aqualuminator?
    May 2015
    Gulfport, MS
    109
    I need to change the bulb in my aqualuminator. Do I need to drain the pool below the light to do so?
    12X20x54" Saltwater 8000 semi-inground, Waterway 1.5hp 2speed 22" Pump Sand Filter, Hayward Goldline Aquatrol HP SWG, TF100
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Drain to replace aqualuminator?
    here are the instructions. looks like you need to block the flow from the inside somehow, they use a hand
    Aqualuminator Light Bulb Replacement - How-to Tips
