Thread: How to repair solar cover seam?
    daleyfolk's Avatar
    Jul 2014
    Boise,Idaho
    51
    This is a fairly new solar cover. One of the seams is coming undone. It's not clear to me what the manufacturer used to originally piece together the strips of solar blanket.
    Anyone have advice?
    I'm thinking of using gorilla glue and clear gorilla tape.
    17.5 K gallons (16x32) vinyl inground pool with 1 hp pump and an old Triton sand filter. >20 years old. New 2015 Rheem gas heater. TF-100 Test kit. Little red robot and a Pool Blaster Max.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: How to repair solar cover seam?
    I think these are heat fused, or ultrasonically welded together at the factory. I would try vinyl patch glue I think. That, or some other backyard engineering will likely have to do. I don't think the tape will last too long, but I'm skeptical.
    Essential Links:
