Thread: TA not coming down
    Dec 2015
    Concord, NC
    19
    TA not coming down
    Yesterday, TA was at 180, with a PH of 7.7. (I have a TF100 test kit). I added half a gallon of MA, and just re-tested - the PH is now sitting at 7.2 but the TA hasn't budged at all - is this normal? Does it just take time for it to come down?
    18x36 roman shaped pool, 27K gal, well water, IG vinyl, 1 HP WhisperFlo pump, Hayward ProSeries Sand Filter S244T
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: TA not coming down
    completely normal it will take some time for the TA to come down.. you can speed it up by using a waterfall or making a sprinkler or pointing a return up to create ripples in the water to raise the PH faster.. this will allow you to drop the TA faster.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
