Results 1 to 7 of 7
Thread: Missing Part
    Missing Part
    Just topped pool up for new season hooked everything up and the cap that goes on the bottom of my sand filter is missing....it is a threaded cap...anyone know what I can do to replace it...Doughboy above ground pool with doughboy filter and pump..
    Without the threaded cap water keeps coming out filter.....
    21 ft Round Dough Boy
    3/4 horsepower Dough Boy PowerPak II pump
    Vinyl Liner
    baqua goo convert
    38,272
    Re: Missing Part
    Just a hunch that it is proprietary threads and may use an o-ring. So, you likely need to find an OEM replacement.
    Re: Missing Part
    can you explain what they all means...
    Also I can't run my pump with out it b/c it leaks out the bottom...it is the spigot looking shaft at very bottom of sand filter...How can I pump and circulate water until I get part?
    Vinyl Liner
    baqua goo convert
    Apr 2015
    South Central PA
    297
    Re: Missing Part
    Google 'lowes pvc threaded cap' - maybe one of these would work.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: Missing Part
    Look inside the filter basket. A lot of times plugs and things get put inside there so they don;t get lost over the winter.
    Re: Missing Part
    That is where we usually put everything...husband is actually the one that closed it down...but not in there is there a way we can still circulate pool water so it isn't just sitting water
    Vinyl Liner
    baqua goo convert
    38,272
    Re: Missing Part
    I guess I am not sure what filter you have and what part is missing. Picture?
    If you do not have a multi-valve that has a recirculate option, then you can not run the pump until the filter is plugged.
