Results 1 to 7 of 7
Thread: Yep, I am definately new!
    aguyindallas's Avatar
    Apr 2016
    Little Elm, TX
    127
    Hey all!
    I am the new guy here today. Our 11.5K gallon pool is currently being built. Gunite is done, electrical is done, plumbing is almost done. Next up, coping and tile. I am looking forward to LOTS of learning here and thank you in advance!
    38,267
    Re: Yep, I am definately new!
    Welcome to TFP!!!
    Congratulations!!! Both for getting a pool and for finding TFP before you have water in it
    Make sure to get your Recommended Test Kit before the pool is filled
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome, look around and check out the forum
    Jun 2014
    15,059
    Welcome to TFP!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    I'll make it unanimous. Welcome
    I'll also echo the test kit recommendation. You're somewhat handicapped in that the builder usually puts all kinds of conditions on the plaster startup, but as soon as possible, you need to take control of the water chemistry. It'll save you hundreds of dollars in chemicals and untold wasted weekends dealing with pool problems if you rely on the pool store.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Welcome to TFP!
    Memorize this before they put water in your pool. Pool School - ABCs of Pool Water Chemistry
    Casey's Avatar
    SW PA
    10,428
    Welcome! Glad you're here!
