Results 1 to 17 of 17
Thread: Unlevel above ground small Intex...help!
    Apr 2016
    Florida
    29
    I dug up sod, asked my preoccupied husband to level the ground then I added a small layer of sand. I assembled the pool and started to fill it yesterday. I noticed it was a little unlevel, but not too terrible I thought. This is what it looks like today "full". Is it really bad? I'm so dreading if I have to drain, take it down and fix the ground. Thanks!
    [Don't mind the soon to be disposed of grass and reed fencing project beginnings.
    38,548
    Re: Unlevel above ground small Intex...help!
    Welcome to TFP!!!
    We generally say that the pool needs to be level within 1".
    Can the Intex pools handle more than that? Maybe yes, maybe no ... up to you to evaluate the risk.
    Apr 2016
    Florida
    29
    Thanks for your reply! What would be the risk? I have three children (aged 7, 5, 3) who will use it 99% of the time.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    That will likely topple sooner or later. The risk is a toddler in the midst of several thousand gallons of rushing water. Sorry, but I'd redo it.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Apr 2016
    Florida
    29
    Bummer. OK!
    Casey's Avatar
    SW PA
    10,461
    Go from the lowest point and remove the dirt. Do not add fill because it will settle. One gallon of water weighs approximately 8lbs. This is why adding dirt just makes a bigger mess.
    Jun 2015
    Stockholm, Sweden
    250
    You dont have to level the ground under the pool, you just have to make sure the legs are all level. Put pavers under the legs and use a transit or water level to make sure the pavers are all the same level.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    sorry but it needs to be redone. Not fun but MUCH safer.
    Kim
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    It might not collapse right away, but it will likely stretch on one side. Why ruin the pool when it can be redone?
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    Quote Originally Posted by 1380ken View Post
    That pool is fine, there is no danger of it toppling over. It looks like it is only out about 2 - 2.5 inches. Try to find a post here, where a pool collapsed because it was 2.5" out of level.
    Would you be willing to bet your 3 year old's life on that?
    I had a 14x42 Ultra Frame that was a couple of inches low on one side. It lasted a couple of years, but once the top rail rusted, it broke at the low spot and the liner ruptured and flooded my yard. It can happen.
    With bigger kids, I would let it go. Obviously, because I did. But with little ones, it would be irresponsible to take that chance.
    Pentair IC40 SWG
    Jul 2012
    Tallahassee, FL
    30,672
    No it is not! We had one that "rolled over" due to being unlevel like that. They got real lucky no one was hurt.
    Quote Originally Posted by jeffchap View Post
    As the age goes up the real trouble starts LOL. The above example about it rolling over was cause by a couple of pre-teens making a "wave" and over it went!
    Every above ground pool SHOULD be within 1" level all the way around. The ground should be lowered to the lowest spot instead of built up with sand or dirt to a higher level as the water will compress it down and cause it to be unlevel again.
    Kim
    Jun 2012
    MA
    347
    Really, so the top rail rusting and breaking had nothing to do with the rupture.
    Quote Originally Posted by kimkats View Post
    Kim
    Do you have any before and after pictures of this alleged rollover? How unlevel was your pool.
    Apr 2016
    Florida
    29
    Thanks all!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    Of course it did, that's why I mentioned it. But all Intex pools are subject to rust out. The added strain caused by the low side made it buckle at that point. I'm not sure it would have collapsed so spectacularly if it had been level. The strain on the top rails is not so apparent now that my replacement pool is level.
    Why are you so adamant to defend your position? Are you going to have to be the one to level it? With small children involved, I will always err on the side of caution.
    You probably think Kim and I are being overly dramatic, but I think you are being reckless with your advice, especially when others' kids are involved.
    Pentair IC40 SWG
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    Is it safe? Is it not? Bottom line, why chance it. If that pool is only 15x48" it's about 5300 gallons which equates to over 42,000lbs. Think about that. 42,000lbs of water...
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    Jul 2012
    Tallahassee, FL
    30,672
    It is a thread from long ago. We tried to tell him but he did not think it was that bad until it went over. He did post a pic after it rolled to show everyone why it needs to be level.
    It is NOT worth taking the chance!
    Kim
    Apr 2013
    Sacramento, CA
    2,769
    I'm missing 1380ken's point.
    AGP are designed, engineered to be built on level undisturbed soil. The mass of the water holds the pool together. Shifting the mass in a manner not contemplated by the designers is not the best move and can lead to catastrophic failure.
