Results 1 to 7 of 7
Thread: It's there anything I should specifically look at when replacing to replace a ladder?
    Aug 2014
    westfield
    60
    Probably a stupid question, but I'm new to all this. The ladder that came with the pool got knocked down by a wind storm and broke. Now, is there a name for these types of ladders? Is the difference between posts standard?
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Re: It's there anything I should specifically look at when replacing to replace a lad
    They are called "A frame ladders" You can go with a standard replacement or spend a little more and upgrade it. A frame ladder
    You might have good luck on craigslist or a local sell app of your choice also.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    Aug 2014
    westfield
    60
    Hi. Thanks for the reply. I thought that the a frame ladders are the ones where both set of feet touch the ground? This one attaches to a deck then goes in the pool. They're called the same thing?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    It might be helpful if you add what type of pool you have, etc.
    Aug 2014
    westfield
    60
    Johnny weissmuller 15x30 x52in with a side deck. We just got it last year, but it was 6-7 years old when we got it.
    Sep 2013
    El Cajon CA
    126
    Quote Originally Posted by askinstuff View Post
    No I assumed that you just had an A frame style by the pic. You can get steps or ladders that will attatch to the deck, DECK LADDER SEARCH RESULTS
    Aug 2014
    westfield
    60
    Thanks!
