Thread: Renovating existing pool. Need advice.
    Nov 2015
    Oxford CT
    47
    Hi, I'm in a middle of renovating area around the pool .The pool is old but works fine. This is my third year with it. It's 10-20 years old .I'm not sure. I've removed the old ugly wood decking around it and now have a choice of just replacing it with composite decking (which is easy) or pour concrete and put a granite on it (which is beautiful and goes with nearby patio. I'd like to do a granite but concerned with accessibility of pipes under it. The underground pipes are fine now, but who knows how long they gonna hold without need of repair.
    I understand that if I put decking it would be much easier to dig stuff if needed vs removing concrete.
    Any insight is appreciated.
    Pictures are below.
    Inground vinyl liner 20 by 40 pool in North East
    Hayward 1,5 HP super flow pump
    Sand Filter
    Nov 2015
    Oxford CT
    47
    Re: Renovating existing pool. Need advice.
    Sand Filter
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Your pics did not show I will wait until you can see what you are working with before I comment.
    Use photo bucket or such to load the pics. Use the img code.
    Kim
    Nov 2015
    Oxford CT
    47
    <iframe width="480" height="360" src="http://s1186.photobucket.com/user/Dmitry42/embed/slideshow/"></iframe>
    Dmitry42's Library | Photobucket
    Sand Filter
    Apr 2013
    Sacramento, CA
    2,769
    Except for freeze damage properly installed pvc pipes last a long time and are generally not the cause of most pool leaks.
    They are better protected with concrete. When Is see your deck the thought that comes to mind is "did he run out of money?" If so what else did he skimp on?
    Now that thought may be wrong because many pools in the East Coast have lawn right up to the pool.
    I vote concrete. It will protect your pool better. As it is this allows water to get directly into the soil next to the pool a problem with a liner pool.
    Jul 2012
    Tallahassee, FL
    30,410
    I agree with ^^^^^^^ I think concrete is the way to go. Add in the granite to make it match the other areas and you will be good.
    Kim
