Results 1 to 8 of 8
Thread: Too Far Gone?
    May 2015
    Smithville
    1
    Too Far Gone?
    Hello TFP Nation!
    My wife and I purchased a home with an in-ground pool last spring. Thanks to this site, the learning curve for opening it last year was shorter than it should have been.
    That said, the pool is jankety at best. I will save you all of the details, but one item of concern this year is a previous patch that has separated from the liner.
    Based on the pics, is the liner too far gone or can we put a patch on the top side to get us through one more year? This fall we will be undertaking a very large pool remodel (all the concrete torn out, all new electric and plumbing, new liner, etc.).
    Thanks in advance.
    Rob
    Brandi & Rob
    20x40 rectangle, in-ground pool, 33,000 gal (according to L x W x Avg Depth x 7.5)
    Sand filter
    Sta-Rite Dura Glas 1HP pump on 1-1/2" lines
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Too Far Gone?
    Hi, welcome to TFP! Looks like it has been patched in that area twice already. You can give it a try, but I'm not too optimistic. If you try you will need a patch about 6" longer than the hole on either side, and as close to the top of the liner as possible. Layer a second, longer patch on top of the first.
    Love TFP? Become a
    TFP Supporter!
    38,285
    Re: Too Far Gone?
    Welcome to TFP!!!
    IMO, trying to patch it at this point seems like a futile effort if it has failed multiple times. Then again, I have no experience with vinyl pools
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,497
    Re: Too Far Gone?
    I would have to at least try! There is really nothing to lose and everything (another year) to gain. Just do not overfill your pool and keep everyone away from that corner.
    Kim
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Too Far Gone?
    If that is the only split you have, I would say go for it, with luck it will make it through one more season.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    Re: Too Far Gone?
    Gorilla tape to the rescue! Kidding, I don't know how to patch a vinyl pool either.
    Jul 2012
    Tallahassee, FL
    30,497
    Re: Too Far Gone?
    Quote Originally Posted by pooldv View Post
    I say why not??? Might be just the thing needed to get another year out of it!
    Kim
    buddywiser's Avatar
    Morgantown, WV
    98
    Re: Too Far Gone?
    You can get another season out of it. My patch kit has pieces that are 23" x 6". It's not going to look good, but you should be able to make it work. You could also think about getting it replaced at the end of the year before you close (if you close). That would save you a little bit of money with not needing to fill the pool to the top.
    24000 Gal, 18x36 Vinyl
    Hayward Super Pump
    Jacuzzi Tri Clops Cartridge Filter
    Heat Siphon Heat Pump
