Thread: Replacing motor for Polaris Halcyon Booster Pump
    rogerbrks's Avatar
    Round Rock, TX
    172
    My booster pump was making a loud noise. Now, it won't cut on. If I need to get a new motor how much am looking to pay?
    21,200 gal IG gunite, CL 580 sqft Cartridge filter, aqua pure salt system, polaris 480-blue&white, Jandy PDA Remote, (4) Jandy Deck Jets
    Re: Replacing motor for Polaris Halcyon Booster Pump
    The motor alone is around $150 to $250 depending on where you get it. You will also need a new shaft seal which will be another $10 to $20.
    Round Rock, TX
    529
    I replaced mine a couple years ago with this one:
    http://www.a1poolparts.com/-strse-1253/ ... Detail.bok
    It is a 3/4 hp booster motor. I really like it a lot. You have to figure out what motor you have now, then find a similar one. Then just remove the motor, replace the seal and put it all back together. The only problem I had was getting the impeller off, but I took it to Warehouse Pool Supply and they took it off for me.
    If you know the motor brand/model you can can go here to find a replacement model:
    http://www.aosmithmotors.com/concertox/ ... rence.html
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
