Thread: When to re-plumb pool?
    Jun 2015
    LI, New York
    24
    My pool is about 40 years old and I believe still has its original plumbing. Every year, without fail, there is a leak which needs to be repaired at significant cost. Luckily for me, the leaks have been pretty close to the pump and have never required pulling up our patio. My question is at what point does it make sense to re-plumb the entire pool? We are considering expanding our patio and I certainly don't want to put money into that project if it will need to be torn up a couple of years later. Is it typical for leaks to occur near the pump or have I just been lucky?
    30,000 gal IG concrete (Diamond-Brite)
    Hayward 1.5 HP Super Pump VS
    Sand filter
    Taylor K-2006 test kit
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: When to re-plumb pool?
    I don't think it ever makes sense to re-plumb a pool unless you need to replace it for other reasons such as replacing equipment. But exactly what is failing in the plumbing?
    Mark
