Thread: Vacuum out filter housing?
    Sep 2015
    Dallas Texas
    53
    Hi
    ive used my pool pump/filter to vacuum out dirt, leaves, etc from the bottom of my pool. When I was hosing off the filter I noticed setiment build up in the bottom of the housing that contains the actual filter. Am I correct assuming I should periodically shop vac out that area to?
    thanks in advance
    Fiberglass pool 5300 gallons (trilogy eclipse)
    inground
    Cartridge filter
    2HP hayward ecostar sp3400vsp
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Vacuum out filter housing?
    I certainly would. Larger, heavier particles will end up down there rather than in the filter. Might as well get them out while you're cleaning.
    Isolated Spa - 345 Gallons
    Jun 2014
    15,153
    That's a good idea. Eventually sand and minor debris can pile-up at the bottom. I clean mine out as well. If you don't have a spigot connection at the bottom to flush it out, then yes, just use your Shop-Vac. Good call.
    Sep 2015
    Dallas Texas
    53
    Thanks!
    inground
    Cartridge filter
