Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: Newbie to site, own pool for 3 yrs. HELP! LOL.
    blueyes39's Avatar
    Apr 2016
    houston, Tx
    40
    Yall will think I am green but I am over loaded with info. I have read so much it has been confusing. I am looking forward to some experienced help here. First, I need to know which kit is BEST for all testing. I will start there. I already know I need to drain my pool, slam it and start fresh. So, with that being said, which kit? I put my pool info in the profile but not sure it will show up lol.
    I have a standard test kit from Leslie's Pools. Chlorine, Bromine and PH tester.
    Darla Reed :-)
    25,000 gal, Nautalis NS60 D.E. filter, Plaster, IG, 30 plus yrs oval pool. Plaster resurfaced 10+ yrs ago.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Newbie to site, own pool for 3 yrs. HELP! LOL.
    Draining may be unnecessary.
    The best kit dollar for dollar, is the TF-100 from TFTestkits.net It has all the tests you will need unless you have a SWG then you need to add the salt test.
    Post a few pics and let's see what we're working with.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    blueyes39's Avatar
    Apr 2016
    houston, Tx
    40
    Thanks Bob! It has some Algae on the walls and a green tintish look in a swirl on the bottom of the pool, I cant get rid of that AT ALL. Pics wont show it, I tried already lol. Ok, I will order the kit right now!
    Darla Reed :-)
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    A SLaM is in your future. It will clear up any algae that we have come across.
    I would suggest you order the XL option of the kit. And add a speed stir, It makes the testing fun!
    Read the following pages while you wait for the kit to arrive:
    Pool School
    SLAMing Your Pool
    Jun 2014
    15,255
    Try to order the "Speed Stir", and maybe consider the "XL Option" size as well since you need to "SLAM". Mix like a pro with plenty of reagents just in case. Great to have you with us.
    30,432
    It'll take about three days to get to you.....don't be frustrated.....it's worth the wait.
    You can make some progress while you are waiting on your kit. Each evening, add a small jug of Clorox (pump running) in front of a return so it is quickly7 diluted. Brush those green spots each evening as well. Don't worry if they don't come out.....we're just getting started!
    Post your test results when your kit comes in and we'll be off and running.
    Also, read "The ABC's of Pool Water Chemistry" up in Pool School, it's the basics for everything we do.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Welcome!
    Just starting out cold, reading Pool School can make you feel
    Once you have a proper test kit and start doing the chemistry, it will click and make sense. There's a fairly steep learning curve as you get things in shape, and after that it's just coasting. Before Memorial Day your pool will be sparkling and you'll be an old pro and bored with the pool maintenance because it's so troublefree and predictable. That test kit will probably have paid for itself by then, too, what with all the potions and elixirs the pool store won't be selling you this year.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Nice one Richard!
    blueyes39's Avatar
    Apr 2016
    houston, Tx
    40
    Lol. Thanks guys. I should have bought the kit 2 yrs ago but use Leslie's to test the water. I know lol. I learned my lesson, only took 2 yrs to get un-manageable so not bad. I did not see an option for the XL kit or speed stir? I did not read that in the info on the site, must have missed it.
    I cant find the 8% clorox around here so I guess regular clorox id ok?
    Darla Reed :-)
    blueyes39's Avatar
    Apr 2016
    houston, Tx
    40
    One other thing, How can I properly measure my pool to find out how many Gallons it really is? It is an odd shaped oval pool, runs from 3.5 ft down to 13 ft. Length plus the widest part width wise? I can take a pic put don't know how to add it to this site, I will use my phone. Thanks!
    Darla Reed :-)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    Use Pool Math http://www.troublefreepool.com/calc.html Towards the bottom it has a calculator to help. If you need to "break" your pool up into part and do it a part at a time and add it all together. We will fine tune it after you get your test kit.
    Great Value Bleach from Walmart (plain, unscented) is what quite a few people use. So long as it is bleach and the % is listed you will be fine. If the % is not listed it is not worth your time.
    Kim
    Apr 2016
    Loxahatchee, FL
    12
    My pool is the same way. I just took multiple measurements at different widths and then took the average. Same with the length and depth. It won't be perfect, but it is closer than guessing.
    18500 gallon oval pool. Filter: Hayward cartridge filter. Model: C12002. Pump: Hayward 1 speed (I think) 1.5hp Max-Flo XL Pump. Model: C48D43AO4. TFT100 test kit.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP Darla, you will be the talk of the neighborhood once you get your pool all sparkly
    espejo's Avatar
    Nov 2014
    Kingwood Texas
    148
    What part of Houston do you live in? Let me know if I can help.
    This reminds me it would be nice if we had a resource set up where we had a list of knowledgeable people in areas of the country or state who could devote a little time to help those new to the process. I would volunteer. I have been extremely impressed with this site and my pool has never looked better.
    40x15 IG, 19,000 gallons, Taylor K-2006C, Intellichlor IC40, Pentiar 1.5 hp Intelliflo VS, Pentair 420 Clean/Clear Filter, Speedstir, Stonescape - french grey, Travertine Paver decking, Completed August 1, 2015.
    blueyes39's Avatar
    Apr 2016
    houston, Tx
    40
    good idea, i am in Clear Lake. We have our own temp table here lol.
    ok, i will try it.
    thanks!!
    Darla Reed :-)
    Chris19D's Avatar
    Jul 2015
    Cypress, Texas
    89
    Welcome Darla! These fantastic people will get you in shape and you'll be managing your pool like a pro in no time!
    Pearland area here!
    ~Chris - 20,000 gallons free-form gunite / Pebbletec, Aquapure 1400 SWG, 2 HP Jandy VS Main Pool Pump, 2 HP Jandy Water feature Pump, 580 Jandy cartridge filter, Dolphin M500, TF-100 w/Speedstir.
    WalMart now sells a 10% liquid chlorine product in the pool section. Unit for unit it is less expensive than their store brand.
    16K IG vinyl liner - 2.5 HP Hayward Pump - Hayward Sand Filter - CircuPool Si 30 SWG
    blueyes39's Avatar
    Apr 2016
    houston, Tx
    40
    I just put the 8.25% lol. I didn't know they had a pool section. Im sure I will need more so good to know!
    Thanks! Had two more inches of rain this morning with more to come over the next 4 days. great. lol.
    Darla Reed :-)
    blueyes39's Avatar
    Apr 2016
    houston, Tx
    40
    Lol. I dont buy a lot of chemicals from them. I used liquid bleach until a year ago, phos free and their shock. I switched to tabs thinking I could save money, boy was I wrong lol. I read the tabs cause lots of problems but I clean and check my pool daily, I thought I could prevent that stuff from happening. Now I am back to square one. Not having the right test kit is my issue. No more short cuts for me lol. I have two bottles of the 10% chlorine left and will add a bottle this afternoon when the sun goes down to kick start my process. My kit should be here by the weekend.
    Darla Reed :-)
  20. Back To Top    #20
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Hello blueyes39 and welcome
    Like they said, it seems overwhelming at first, but gets MUCH easier with time. And remember, your way ahead of the game, it took some of us (me) 17 years to find this place
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
