Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Pool guy put a little too much muriatic acid in my pool....advice please!
    Apr 2016
    Youngsville, LA
    274
    So for some reason my pool guy put a gallon of muriatic acid in my pool bc my pH was 8.0 and he was obviously trying to get it down. I wanted to get it down around 7.2-7.4 range but unfortunately it is now probably about the 6.8-7.0ish range when testing with my Taylor 2006 kit. My TA also dropped (of course) from 60 to 40. I asked him why he put so much MA and he said "bc I shocked the pool (15k gallons swg pool) with 2 bags of shock and it will raise the pH so I was added more than it called for of MA to counter this". Regardless, what's done is done. It's 3 days now and hasn't come up above 7.0 and the TA is still 40, so I was going to adjust it back myself. My plan is as followed:
    1) Adjust TA first with Baking Soda (Sodium Bicarb) to bring it up to 60-70 range then...
    2) Test pH to see where I stand, and adjust accordingly with Soda Ash (Sodium Carbonate) to bring up to 7.2-7.4 range
    Does this sound right?
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin Nautilus Plus Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    Jun 2014
    15,145
    Re: Pool guy put a little too much muriatic acid in my pool....advice please!
    I would raise the pH right away as that can be the most corrosive to your water/equipment. You can use Borax which may also raise TA slightly. After adjusting pH back to the mid 7s, your TA may make it to the 50 range which is fine for now. Then tell the pool guy to never come back.
    Apr 2016
    Youngsville, LA
    274
    Quote Originally Posted by Texas Splash View Post
    Can I find Borax at like Wal-Mart, Lowe's, Home Depot, etc? I plan on going pick some up today. What is the best way to add it to the pool? Pour in deep end and brush? Can I leave the pump on? I only have him to clean the pool, vacuum, empty baskets, etc every other week and test the chemicals. He wasn't suppose to ADJUST chemicals, but I never implied that to him, I thought he understood that from the beginning but maybe that's my fault.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Yup, fire the pool guy. Why is he "shocking" the pool. Following TFP methods we don't shock for the heck of it. Maintain proper FC level and you are good to go.
    He is taking money from you that could be better spent on family.
    Support the site
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Dichlor shock is acidic while cal-hypo shock is relatively neutral (iirc). Either way, no reason to add acid to "counter" it. FIRE THE POOL GUY!
    Isolated Spa - 345 Gallons
    Jun 2014
    15,145
    CG, Borax is available as 20 Mule TeamŽ Borax Natural Laundry Booster. It is sold in the laundry detergent section of most larger grocery stores and some big box stores. Borax is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return. Yes, leave the pump running while you add and make sure it's blended into the water.
    Apr 2016
    Youngsville, LA
    274
    Thanks for the instructions, I'll be sure to mix it up first with some water then pour in pool in front of return jet! Pool Calculator says for 15,000 gallon pool with Alk of 40, to add 40oz of Borax to bring pH up from 6.9 to 7.2 does that sound about right?
    Jun 2014
    Roseville, CA
    343
    And as you are firing him, explain to him what he did and how irresponsible it was. Then deduct the cost of additional chemicals from his bill, or you will destroy him on Yelp.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Here is our chemical cheat sheet, Pool School - Recommended Pool Chemicals
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Also just a note: If the pH is near the bottom of the scale, it might actually be off the bottom. So it may take more than one attempt to get it up where you want it.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2014
    15,145
    I got 42 ounces, but close enough. But curious, why stop at 7.2? Your IG SWG pool should have a min 7.6, so you could add 70 ounces to get to a pH of 7.6.
    Apr 2016
    Youngsville, LA
    274
    The only reason I had him was bc we just moved into the new house and needed a little help with CLEANING the pool (every other week) for just month or two until my wife and I were able to get the house and yard situated. He actually has done a really good job cleaning the pool....he needs to just stick to that! I've already let him know my concerns and NOT TO ADJUST ANY CHEMICALS. He said he will leave me the numbers he gets and I can adjust chemicals from there, he will just clean pool. I've got my Dolphin Nautilus Plus in and most of my other cleaning supplies, so I will only need him to come maybe 1-2 more times and that's it bc we are almost done unpacking (it's hard two small children to get everything accomplished in a timely manner lol). Thanks for y'all advice!!!
    Well I have a little calcium buildup around waterfalls and it was my understanding that to keep the CSI at zero or slightly negative (to fix the issue), that I need to keep my pH around 7.2-7.4ish range?
    Jun 2014
    15,145
    Oh, gotcha. That's fine then. You're watching it ... good.
    Apr 2016
    Youngsville, LA
    274
    Update: So I'm a bit confused now. Yesterday evening I went out and added 16 ounces of soda ash (sodium carbonate) to bring my pH up from 6.9 to 7.2 because according to the pool calculator for my 15k gallon pool it would take 18 ounces (I just put 16 ounces to be safe). Checked it again this morning and it is now OVER 8.0 again!? Any ideas why? Did I calculate something wrong?
    DFW, TX
    24,497
    Did you have all of your other test results loaded in Poolmath? PH chemistry is relational to some of the other measurements. What is your TA?
    Feb 2014
    Central Minnesota
    5,080
    That should have only raised your pH by 0.4 to 0.5 and your TA by about 7. However, since your starting TA was at 40, your water may not have great buffering capacity, leading to the wild swing in pH. TA is a measure of your water's ability to buffer pH changes due to environmental and chemical additions (in general). I would retest your TA, then increase your TA to 60 using baking soda, without attempting to change the pH again yet. After you've brushed and circulated for an hour, retest your pH.
    Apr 2016
    Youngsville, LA
    274
    Quote Originally Posted by JVTrain View Post
    Ok thanks! I added a little bit of MA this morning to at least knock it down a little. I will picking up some baking soda and adjust TA accordingly. It was at 40 last time I checked, but I'll recheck again before I add baking soda. I'll report back with the results.
    Apr 2016
    Youngsville, LA
    274
    So just to clear things up...when both the pH AND TA are low, is it best to adjust TA FIRST, THEN pH or vice versa?
    Feb 2014
    Central Minnesota
    5,080
    In my opinion, pH should be adjusted first. Low pH can be more immediately harmful to pool equipment, mostly heater element plumbing but other items as well if left low for long periods. pH can fluctuate a lot with low TA so a small adjustment to bring it to 7.2 or above is best, then look at adjusting TA. Low TA is not harmful to equipment on it's own, but a low TA with low CH and (combining for a very negative CSI) could damage plaster pool surfaces over time. A concern but not as immediate as pH.
  20. Back To Top    #20
    Apr 2016
    Youngsville, LA
    274
    Ok sounds god, thanks for your advice! I'll get another set of numbers today and adjust accordingly. Should I use maybe half of what the pool calculator says and then recheck? I'm kinda worried about putting the full amount after what happened when I added the soda ash.
