Thread: Question on leak fixes
    Apr 2016
    Murfreesboro, TN (Middle TN)
    103
    Now that my water is crystal clear thanks to this helpful forum, on to fix other things.
    I have noticed during my slam I keep losing water, and had hoped it was only due to me removing the cartridge to clean it. But I topped off again yesterday and am down to 1/4 skimmer when I was nearly 2/3 yesterday.
    I can only see 2 clear signs of drips, one from the return as seen here
    And I see some water pooling around the seal on my filter housing
    I ordered new seals for the hayward filter, but what should I do on the return? Should I just replace the entire assembly? Do I need to drain down for that?
    27' above ground, 17500 gallons, Cartridge filter Hayward SW1000z4, A.O. Smith Pump SP1515Z1BC 70 GPM, Test kit Taylor TF-100
    Murfreesboro, TN
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Question on leak fixes
    A new seal will probably do wonders for the filter.. On the return/suction it looks like it is all screw fitting where the leak is, you may be able to unscrew everything and use monster tape on the threads
    Amazon.com: 2 PACK- Milrose 70885 Blue Monster 1/2 Blue Teflon Tape: Office Products
