Thread: Question for pump gurus (troubleshooting)
    Oct 2015
    Woodlands, Texas
    8
    Hi all,
    I had posted this as a continuation of a question I had about cloudy sand in my pool in another thread, but as my question now shifted to pump mechanics I thought I'd move it here. Any help would be greatly appreciated!
    Quote Originally Posted by WoodlandsJacket View Post
    Good news for anyone following along. I think the white dust was just a byproduct of all the leaves and organic matter breaking down.
    After running the pump for 24 hours it was almost all cleared up and I didn't have to add anything to the pool.
    Only thing is now my pump seems to be busted? I turned it off (service mode) to clear the filter of the sandy mess at the filter integrated into the pump (challenger pentair made by century centurion) and when I went to turn it back on I can hear power going to the pump but it won't move water and then clicks off audibly after maybe 5 seconds. Seems like it is also overheating. Luckily we have a home warranty so I'm hoping it is covered and can get it fixed!
    22,000 gal SWG plaster pool with spa and waterfall wall.
    DE Filter; Gas Heater; AquaRite system
    Oct 2015
    Woodlands, Texas
    8
    Re: Question for pump gurus (troubleshooting)
    I tried, for lack of a better term, "jiggling" a wire coat hanger around into the intake pipe but could only get it maybe 2 inches past the opening. I pulled the filter basket out and cleaned it completely then replaced it correctly. Not sure if I need to do something else to check the impeller or if it sounds like I did it right.
    I tried filling the pump with a hose, ran it for probably 10 minutes at 3/4 strength flow but it seems to continue to drain through the system as opposed to ever actually filling up. I hope that doesn't mean a leak has sprung somewhere?
    Oct 2015
    Woodlands, Texas
    8
    For anyone still following along, sounds like the motor was shot. They are going to replace it with a rebuilt motor (through my home warranty) and I am hoping it gets me through the summer. I planned on upgrading the heater/pump set up this fall anyways to get better warming results.
    Thanks to everyone who offered suggestions in the other thread!
    Jul 2015
    TN
    11
    Our first yeah I this home with a pool. July will ne one year. Prior owner had the shaft seals leaking killing the motor. Without a squirrel cage blower running airflow over pump motor it would trip off on thermal overload. Nursed it over the summer but now trying to find the best value in a 2 speed-230V pump.
    In in my limited pool knowledge it seems pump is shot or has a major blockage causing it to work really hard.
    Good old luck OP.
    20x40 inground liner pool.
    Hayward SP1030x152az pump
    1.5 HP two speed pump.
    polaris 3/4 HP booster pump
    SWG and controller
