Thread: Use of SWG
    Mar 2009
    Macon Ga
    77
    Use of SWG
    Hello all, I have a question on using the SWG to shock the pool. Is it just due to the shorter life of the cell or are there other reasons also. Thanks
    18X38 Grecian 26000 gallon In Ground Vinyl. Goldline AuqaRite SWG with a 1.5 HP Pentair Pump. Triton 2 Sand Filter Two main drains with 4 main returns with 2 more returns on the swimout and two skimmers. Polaris 380
    30,421
    Re: Use of SWG
    The shorter life of the cell is an important factor but, even more important, it does not have the capability to produce enough chlorine fast enough to adequately shock your pool.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Use of SWG
    I believe it will take quite a bit longer to reach shock level (if it even can), which kind of defeats the purpose of shocking (lots of chlorine right now, as opposed to over hours).
    Mar 2009
    Macon Ga
    77
    Re: Use of SWG
    So Dave when I shock the pool with bleach I should turn off the SWG? Thanks
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    Re: Use of SWG
    Quote Originally Posted by kenmccall
    As long as your salt level is fine, it is OK to leave the SWG on.
    14100 gallon IG Gunite Pool
    Sapphire Smoke Quartz Plaster
    Pentair SunTouch Controller, Intelliflo 4x160 Pump, 520 Cartridge Filter, Intellichlor SWG System
    Legend Platinum Cleaner with booster pump
    My Pool Build
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Use of SWG
    However, when conducting an "overnight test" to see if the FC is holding, one must shut the SWG off, to ensure the accuracy of the test. Only when the FC is holding are you "done" shocking....(plus cc .5 or less, clear water )
