Thread: Should I adjust levels?
    May 2015
    Kaplan louisiana
    68
    I slammed for roughly a week and left for 5 days to go to work. I just got home and tested my pool and the results are below. Should I adjust anything? I did pass an OCLT before I left for work and had dropped my cc from 1 to 0 during the slam. I know the pool needs to be vacuumed and I'll be doing that this morning.
    Fc 10.5
    Cc 0
    Cya 40
    Ta 50
    Ph 7.2
    Ch 50
    13500 gallon above ground with pentair sand dollar sand filter, 1.5hp pentair pump with TF-100 test kit. Kaplan, Louisiana
    Jun 2014
    15,093
    Re: Should I adjust levels?
    If those test results are from today, you could simply let the FC sink back down to about 5-6. pH could go up slightly to about 7.5 by using some borax which will also increase TA slightly which should good for you right now. Overall looks good.
    May 2015
    Kaplan louisiana
    68
    Thanks, I'll let the FC drift then adjust PH and Ta with borax. These test results are from abou an hour ago.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    If that stuff on the floor goes "poof" and disappears when it gets nudged with a brush or vacuum, it's algae, and you're not quite done. Remember, you have to pass all three tests simultaneously to call a SLAM done. Vacuuming up everything and brushing is step one. If the water still looks clear after brushing and no more debris settles out after you're done, that's one; the water is clear. It looks like you've got part two down; low CC. If you pass the overnight test tomorrow morning, that's the third piece of the puzzle.
    Assuming you pass all three at the same time, then let the FC drop to 5 or 6. It looks to me like maybe just a little baking soda will fix you up. That'll raise TA and nudge pH just a hair. Over time the pH will rise some more.
    May 2015
    Kaplan louisiana
    68
    Thanks, I'll do another oclt tonight after vacuuming to see where I stand.
