Thread: Stenner Kit??
    Mar 2013
    CT
    351
    Stenner Kit??
    If i buy a Stenner pump, is there a complete "installation kit" that is available that includes the fittings , hose, check valve etc or do i need to purchase each component separately??
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Aug 2014
    Austin, TX
    74
    Re: Stenner Kit??
    The pump comes with everything you need (20' discharge tubing, injection fitting, spare pump tube, suction strainer, etc) except the tank and a tap into your plumbing. If you get the high pressure pump, the injection fitting is also a check valve. On the low pressure pump, it's only an injection fitting.
    If you buy the tank and pump combo, the suction line/strainer is pre-installed and the pump mounted on the tank.
    All you need to do is tap into your plumbing (1/4" or 1/2" tap, either will work) and hook up electrical with some kind of timer. The only thing on the pump is an on/off switch.
    12300gal IG PebbleTec w/7' raised Spa & Waterfall. Built Aug 2015
    Pentair IntelliFlo VS Pump, Pentair 420 Cartridge Filter, Ultra UV, Auto Fill
    EasyTouch control w/ Remote, Infloor Cleaner w/1.5HP Pump and Leaf Canister
    Stenner 45MPHP10 w/15gal tank, Rainbow 320 Chlorinator, TF-100 Test Kit.
