Thread: Timer Recommendation Needed
    Mar 2013
    CT
    351
    Can anyone recommend a good quality digital timer that won't break the bank...
    Thanks!
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Timer Recommendation Needed
    Is there a specific reason you want to go digital rather than a mechanical? I have an Intermatic mechanical timer and it's basically bulletproof. Intermatic also makes very good digital timers as well. My mechanical timer is a T104PCD82, plastic enclosure. The PE153 series would be a similar timer, but digital. I believe for these digital timers, some have the option of adding a remote control, which I admit sometimes would be nice! Your pump specs are not listed in your signature so just be sure that if you have a 2 speed or VS pump that your timer can handle it.
    Isolated Spa - 345 Gallons
    Mar 2013
    CT
    351
    The digital timer will be for a Stenner pump. I have a mechanical timer on my filter pump already.
    Feb 2014
    Central Minnesota
    5,080
    In that case, I would check out threads in the Chemical Automation and The Liquidator for folks documenting their builds. Lots of great ideas there!
