Results 1 to 11 of 11
Thread: Automatic acid system help
    Aug 2014
    NJ
    435
    I have had my pool for only one season, and check chemicals regularly, but have found that the only chemical I need to constantly put into my pool is ACID to lower my PH. Last season (my first), after adding salt, CYA and CH, I hardly made any adjustments to them all summer. I would like to add an automatic acid feeder to my system, but have the following questions.
    1. My strong preference would be to have a feeder that reads the PH electronically and calculates the necessary amount of ACID to add. I understand that a fixed rate pump would probably work fine, but I would enjoy having an electronic reading of PH to compare to my own calculations. On the other hand, if the calibration went astray, I would like to be able to use just a fixed rate addition of ACID. Is there any system that would give me the option of using its calculation of PH to make the equivalent addition of ACID while also permitting me to forego such precision and instead have it drop a fixed rate throughout the day.
    2. I have an AQUALINK 2.0 (with free relays) and would like whatever system I get to linkup with it so that I can monitor PH from my phone and compare it to my own testing without going to the PAD to see its measurement. I would also like the ability to increase the fixed rate via my phone.
    Below are some pictures of my PAD (they not the best pictures but hopefully they show enough). Thanks for your help.
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Automatic acid system help
    There are steps that you can take to reduce PH rise and lower acid demand if you are interested in pursuing those before getting an acid dosing system.
    Reduce aeration by running bubblers, waterfalls, etc less
    Lower your TA to 50/60
    Add 50 ppm borates
    If not, good luck in your search.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I noticed last year that as I added acid to drop my ph, my TA dropped down to around 60 over the season and I ended up adding acid less often each time.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Most here are not really keen on the auto ph monitoring / dispensing devices. There are some reliability and related maintenance issues that can introduce more headaches than convenience (e.g., these sensory/monitoring systems are more complicated mechanisms and hence, are just another component that can go wrong or have you investing time getting them to perform as designed).
    I'm all for automation. I have set up a stenner pump acid injection system that, although it does not automatically call for acid when ph is low, it still is a real time saver. Once you dial in the dosing time that gets you to a steady ph level, its just a matter of minor adjustments of the timer to get your ph where ever you want it. For me, when I see that my PH is starting to creep up (I only have time to do a quick ph reading on Saturdays), I just add an extra minute to my dosing time and check it the next week. This really is a minimal amount of time and I have been getting some real rock solid ph levels compared to when I was added acid manually.
    But again, if there was a reliable and relatively inexpensive and trouble free sensing/auto ph dispensing system, I'd have it installed already.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    Aug 2014
    NJ
    435
    Thanks for advice everyone. I prefer not to limit my aeration or use borates so I would like an automated system. Is there a system that could be used both ways - an electronic sensing PH that dispenses acid based on its calculation of PH as well as a simple time dispenser if I wanted to forgo the electronic calculation?
    Thanks.
    DFW, TX
    24,509
    The only one I know of is this one, but I don't know much about it.
    http://www.pentairpool.com/products/...roller-434.htm
    available here
    Pentair IntellipH pH Controller 521377 | Pentair 521377
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    The IntelliPH does not have a pH sensor. It is a simple percentage based dose every hour, similar to how a SWG operates.
    The automated systems you are looking for all offer ORP sensing for chlorine production/dosing. ORP sensors have been known to be unreliable and subject to interference. If you were to get one of these systems, you'd likely end up disabling the ORP side of the system. Your money would be better spent on a time based system similar to a Stenner.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Aug 2014
    NJ
    435
    Quote Originally Posted by bdavis466 View Post
    Thanks. So what is the difference between a Stenner ( which I have seen people talk about here) and this IntelliPH? I agree I wouldn't use the ORP but liked the idea of having an electronic PH because I can never tell exactly what the PH is based on the color test.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    The biggest difference is the IntelliPH, being a Pentair product, must be used in conjunction with a Pentair SWG. Since you have a Jandy system, stick with their product or go with a Stenner which can work with any system.
    They are very similar products otherwise.
    -Brian-
    POOL BUILD
    Apr 2011
    Maryland
    18
    This has worked well for me
    Solaxx PH Tek Acid Feeder
    18000 gal Gunite free form
    Jandy 1 HP pump
    Jandy DEV 48 filter
    Raypak 400 heater
    Goldline Proligic SWCG
    Solaxx chemical feeder
    Dolphin Deluxe 4
    Nov 2016
    Sacramento
    2
    How do you set up a stenner pump acid injection? I downloaded the manual but it is not clear to me how to set the dosing. Your post mentions you adjust the dosing time, how do you do that? does the pump come with a timer? Thanks for your help!
    New pool, inground 12 X 28, gunite, pump Pentair VS superflow 1.5 HP, filter Pentair 420 clean & clear, Auto Pilot nano+
