Results 1 to 13 of 13
Thread: solar blanket solution
    Kathe's Avatar
    Jun 2015
    Saline, MI
    47
    IMG_1131.jpgI just wanted to share with you what we did to make removing our solar blanket easier for our above ground pool. I'll give you the possible negative first... you have to be in the pool to do this. But then I'd be getting in to swim anyway.
    I bought 4 2.5' bungee cords with the hooks covered in a thin plastic at Ace Hdware. I hang the cords around my neck and get into pool. I push and sort of accordian pleat the cover as I go towards the other side. I hook the cord over the rim and hook the other end over the cover and under it, hooking that end onto the underwater rim. When I say rim, it is not the "side of the pool" but the rim of the piece that fits over the side of the pool. I hook the other cords spaced to secure the blanket around the inside curve of the pool. I still have plenty of room to swim and the blanket is floating on the water and so no heavy lifting is required. When we are done swimming, last one out unhooks the cover and unfolds it by letting it redrift over the water. Sometimes takes a little bit of maneuvering, but you would get the hang of it. No wear and tear on the cover and one person can do it.
    I'm also planning to experiment a bit with "Heatsvr" liquid cover. Our heat pump needs repairing and so no heat right now. I'm not planning to jump into 70 degree water while it is only 60 outside. So no cover on pool yet. I thought I'd try some liquid cover to see what it did. Anyway....Happy Swimming Season!
    Above ground 27' round, 17,000 gal., 52" high; vinyl liner; TropiCal 96,000BTU Heat pump; Integrity A Frame Ladder; Solar Blanket, Aqua Cover by PolyAir Corp, thermotex clear, 5 yr. warranty, cartridge filter., Clear Bay Cartridge CBA2-10043 (two to switch out when cleaning); New pool as of 6/1/15.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: solar blanket solution
    I don't mean to be negative, but I would not trust liquid
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Casey's Avatar
    SW PA
    10,457
    Ive used the bungee cord method and it works. I would love to invest in a solar reel this year though. I'm buying a new solar cover next week.
    Kathe's Avatar
    Jun 2015
    Saline, MI
    47
    I figured that since I'm not using the cover right now, I'd just try it for myself. I'm sure we will go back to the cover unless I find that the liquid works. People seem to be split on whether it works or not. I know the cover works. Do you have any experience with the liquid?
    And here I thought that I'd invented this inexpensive method...LOL! It does work!
    JoyfulNoise's Avatar
    May 2015
    13,251
    The liquid mostly slows evaporation which is the largest component of heat loss in a pool. The water can still radiate and convect heat away. The major downside to the liquid approach is that the surface of the water has to be ABSOLUTELY still or else any ripple will immediately breakup the liquid film. Unless you live in a very sheltered area with no wind, then it will not work very well.
    Also, the liquid tends to leave a scum/dirt line at the water's edge that had to be cleaned off. Chlorine can make the scum line very tacky so it's best to not let it "age".
    Matt
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    A good product for above ground pools is the solar saddle. Essentially J shaped pvc hooks that allow you pull the cover out of the pool and hang in on the side. I think i paid 90 or 100 bucks for it and it was worth it (though certainly more than the cords). I put an inground pool in last year and b/c I didn't want to bother with the solar cover anymore I figured I'd try the liquid. It was pretty good. Not as good as the solar cover but it helped reduce the heat loss compared to having nothing (so I felt anyway). I'm going to use it again. Worth it imo to be able to skip the hassle of the solar cover. I keep my pool open and heated from mid May through mid September and my gas bill was never more than $90 for the month with the heater and grill going. I keep the pool at 86. If my neighbor forgets to put their solar cover on I can see the evaporation in the mornings (though they may keep their pool considerably warmer than I do, I'm not sure what they keep it at).
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    Kathe's Avatar
    Jun 2015
    Saline, MI
    47
    Did your liquid cover gunk anything up? Scum?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Quote Originally Posted by Casey View Post
    I bet you could DIY one from some 2" pvc...
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Apr 2015
    New York
    428
    Hi. No. I get gunk buildup from the tons of suntan lotion we use but it's not gummy. Nothing changed when I used the liquid (too bad it didn't dissolve the lotion, haha).
    Jul 2012
    Chicago, IL
    358
    Thanks for sharing, I usually role the cover up on a pvc pipe and lift it out, but I've been looking for something that my wife could do in a pinch or when just hopping in with the kids for a quick swim during the week. This should do it!
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Kathe's Avatar
    Jun 2015
    Saline, MI
    47
    Just wanted you all to know that I did indeed put liquid Heatsvr into pool. 4 oz. Last night water was 60 degrees. Air got down into 30s last night. Pool water was 58 this am. Not bad. I do have soft ripples on pool due to running pump on low. I notice no haze. Bugs seem to float on top which makes them easy to skim off. I can't run our heat pump right now due to waiting for repair.
    Jun 2016
    Port Orchard
    15
    Here's what i did this year with ropes and pulleys.
    I can uncover and re-cover in seconds by myself.
    DIY solar cover solution for 24 round pool. Bike powered, haha - YouTube
    Jun 2017
    Ottawa/ON, Canada
    65
    Love your setup, it's gorgeous. I wish we had space around our AG for a deck, we're squeezed into a narrow yard. BUT - once we're in, we're happy. I've just unpacked my solar cover, and put it on myself in the pool. So cumbersome. I like your bungee idea. Looking at building a reel though.
    12'x24' Aqualeader Sentinelle 54" deep AG (7000 gallons/ 26,500L) - Jandy jxi 260,000 btu gas heater, Hayward Aquatrol salt system (SWG). nature2 water purifier. 1.5hp pump/ 22.5" sand filter. Install July 2017. Taylor 2600 test kit. Solar cover and reel.
