Results 1 to 7 of 7
Thread: First test with the T 100
    Dec 2015
    Newington, Connecticut
    113
    Got my first test results with the T 100. Brought cold sample inside and brought up to room temperature.
    Water temp. 70 degrees.
    CYA 40
    FC 2ppm
    CC .5
    CH 225
    TA 130
    PH 7.8
    Will shock tomorrow using these readings and cya chart
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: First test with the T 100
    What does the water look like? If it's clear, you might not need to SLaM it.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Aug 2014
    Northern IL
    4,615
    I agree. Bring your FC up to target for now. I wouldn't wait until tomorrow if you can add some chlorine tonight.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    Numbers look good. With TA at 130 your PH might tend to rise. When it rises to 7.9-8.0 lower it to 7.6. You can let your TA drop if it lowers when you add acid to lower PH. Anything as low as 60 is fine, wherever it ends up through PH adjustments.
    Dec 2015
    113
    Water is very clear after vacuuming. I was just reading about shocking and realized my levels are not above .5. Also water temperature is low. 50-55 degrees. Will get fc up to 5 and maintain.
    DFW, TX
    24,512
    Good plan! Wait for the pool to warm up and
    Dec 2015
    113
    Thanks for all the advice, much appreciated
