Results 1 to 7 of 7
Thread: Wedding cake step pad?
    Apr 2016
    Gate City, VA
    8
    New pool owner here (of an old pool). I took the wedding cake steps out of my pool for the winter, pretty sure its the first time they have been removed!! Lots of debris/leaves underneath. There was 4 bags of sand totally greened up but still in one piece (barely) holding the steps down. There was one step pad that was duct taped to the back of the stairs between the wall and the stairs. When I put the stairs back in, do I need the pad on the back of the stairs or the bottom? Or both? Also is there any downfalls to cutting the pad to fit and gluing it to the back/bottom of the stairs?
    28' Round Above Ground Pool (1999?) 17,000 gallons
    Pump -Hayward Power-Flo LX Pump 1.5 hp
    Sand Filter - Hayward Sand Master
    1 Skimmer
    1 Return
    linda1's Avatar
    Mar 2010
    Western Pa.
    297
    Re: Wedding cake step pad?
    I've had my wedding cake steps for 5 years and have never used a pad under them. Haven't had any problems.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Welcome!
    If you use the search box up in the corner for "wedding cake" you'll find hundreds of old threads. Some of them discuss weights that don't breed algae. Some also show how people have made holes to allow better water flow to keep algae away. I'm also pretty sure there are posts about pads. I recall rubber shower mats as one solution, and possibly a slit pool noodle, but don;t quote me on that.
    Jan 2010
    Randleman,NC
    620
    Rubber tub mat's works great.They stick and stay
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Apr 2016
    Gate City, VA
    8
    Thanks for the feedback. I have been doing quite a bit of searching and haven't found anyone that has mentioned glueing the pad to the steps. I am thinking that is the route I'm gonna go, so maybe I will be the first person to post about it!
    1 Skimmer
    1 Return
    Jul 2012
    Chicago, IL
    356
    I think that could work. Last season a few of us re-purposed some home depot plastic shelving units to make platforms for kids. I took cabinet liner and used JB Weld to attach it to the bottom and it worked well.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Jan 2010
    Randleman,NC
    620
    Not sure on glueing.I've alway's got the heavy duty Clear bath mats from Walmart that have the suction cups on them.I just lay them on the floor and set step's on them.
