Results 1 to 8 of 8
Thread: Water cleared, low readings
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    I took a pH and FC sample, had almost no chlorine and about 7.8 to 8 pH. I added 2 gals of bleach. I took a reading 6 hrs later and the FC was up to about 4.
    Today I took another reading, and the FC is close to 1. I took the CYA,, and it is about 26 (according to the black dot test).
    According to the poolmath calculator, I need to add about 106 ounces liquid CYA and 1.5 bottles of bleach. Does it matter in which order and does one have to sit before adding the other?
    Thanks in advance
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Water cleared, low readings
    Quote Originally Posted by dw9000 View Post
    Thanks in advance
    Add the CYA first, because the higher CYA means you will need to target a higher FC. The liquid stuff will be active within minutes, certainly within hours, so you need to use the estimated CYA value as the now value and set the FC target accordingly.
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Great thanks, that liquid CYA is kind of pricey,,, does this powder/crystal look ok? According to the amazon reviews, it is 100% cya I can use a sock and wait a bit longer....
    Cartridge Filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The powder is fine, we suggest you hang it in an old sock in front of the return as it is very acidic and dissolves very slowly
    Richard320's Avatar
    Jan 2010
    19,071
    The granular is fine. So the target FC stays down at 3 until the sockful is dissolved, then it goes up.
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    So do you suggest I add the CYA (hanging a sock in front of a return)? Let it all dissolve? Retest in a couple days,, then add the chlorine?
    Cartridge Filter
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    You can add your chlorine while the CYA is hanging. Once it is all dissolved, dose your chlorine at the target CYA value. It may not show up on the CYA test right away, but it will be working. You should always keep your chlorine above the minimum for your CYA.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    The chlorine needs to be added now to keep the water from going green. Chlorine and CYA work together very well. Target your FC as if the CYA is already in the pool.
    Kim
