Results 1 to 12 of 12
Thread: EC40
    May 2015
    pittsburgh pa
    62
    EC40
    Hi, winter cover fell in so opening early in pa....
    unfortuantely, a lot o junk on the cover fell in creating some algae.
    My EC40 which i bought last year pressure rising pretty quick and not filtering very good because of. I took it apart, the fingers were dark green. Hosed them down, put filter back together and seems pressure still rising fast. Any thoughts on what the issue might be?
    11,000 gal (21' round) AG
    DE EC40
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: EC40
    It's clogged with algae. It's going to keep doing it until you get it all killed and filtered out. DE filters are the best at filtering and therefore the worst about clogging. Keep bumping until bumping doesn't last, then follow the cleaning routine and recharge. And follow the SLAM procedure so you get that algae killed faster than it can reproduce.
    May 2015
    pittsburgh pa
    62
    Re: EC40
    Thanks Rich, getting the liquid chlorine together. Got sidetracked by some groundhogs
    DE EC40
    May 2015
    pittsburgh pa
    62
    Re: EC40
    Pools looking real good, but i have another question about the EC40 (this is my second season with it).
    Sometimes after I take it apart to clean out the inside parts, put it back together carefully. When i start up it seems the basket in the pump doesnt fill up all the way, i.e. have bubbles. I've checked the hoses for any air cant find anything.. Sometimes after it runs for a while they'll mostly go away.
    Is there some trick or sequence i should be following to get it to run well quickly?
    Tony
    DE EC40
    May 2015
    pittsburgh pa
    62
    Re: EC40
    Any thoughts?
    DE EC40
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: EC40
    Try turning off the pump, unscew the pump basket lid just enough to let the air bleed out (carefull not to unscrew it all the way or water will gush out at you). Turn cover back tight and pump on.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: EC40
    What I typically do for pools with any of the finger-type filters - is use a submersible pump to circulate the water while slamming. Once the algae is dead, the EC's don't clog as fast as they do with live algae.
    It sure would be nice if they all came with filter bypass valves or multiports to vacuum to waste. Pool life would be so much easier.
    You can create a syphon by holding the vac plate up to your return (if it's not one of those aerator ones) and leave the other end of the hose out of your pool on the ground, and vacuum to waste, bypassing your filter and saving lots of DE. This only works on AG pools...
    May 2015
    pittsburgh pa
    62
    Re: EC40
    Quote Originally Posted by frustratedpoolmom View Post
    what submersible pump? Pic our model would be helpful.
    DE EC40
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: EC40
    Harbor Freight sells some inexpensive ones.
    May 2015
    pittsburgh pa
    62
    Re: EC40
    Quote Originally Posted by banditig View Post
    Thank you, this helps out immensely! I also found out that my water may have been a little low. With rain it was up around the middle screw in skimmer, and zero air bubbles. Will shoot to keep it there...
    DE EC40
    May 2016
    Troy IL
    476
    Re: EC40
    here's a great inexpensive submersible one. you have to wait for them to ship to store, but it's a great pump at a great price.
    Superior Pump 1/4 HP Submersible Thermoplastic Utility Pump-91250 - The Home Depot
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    May 2015
    pittsburgh pa
    62
    Re: EC40
    Quote Originally Posted by camueller View Post
    Old thread, but opening with algae again. do i just put that submersible in and what while slamming?
    DE EC40
