Thread: Home Depot Chlorine
    Jul 2015
    Poway, CA
    58
    Home Depot Chlorine
    How do you decode Home Depot's chlorine date? Thank you for all of your help!
    27K Gal, IG Plaster, Hayward EcoStar Variable Pump, Pentair DE FNS Plus Filter 24, Hayward AquaRite with extended life T-CELL-15
    The Pool Cleaner Sweep
    Build in 1969
    Water From City
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Home Depot Chlorine
    That's the 49th day of 2016. That makes it February 18th. Today is the 115th day. http://www.fs.fed.us/fire/partners/f...n-calendar.pdf
    Jul 2015
    Poway, CA
    58
    Thank you! I will be returning it. Do you know where to purchase less the Leslie's Pool Supply ($9.98 for two gallons)?
    Build in 1969
    Water From City
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    18,995
    See if there's anyone close to home or office http://www.hasapool.com/dealer_locator_hasa.php
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Many Walmart stores around the country have had 10% Pool Essentials brand on sale for $2.50 per gallon (regular $3.69).
    chiefwej
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I doubt you will save anything returning it given the time it takes, while it is not extremely fresh, it is likely not just overpriced salt water either
