Thread: Pool winter cover and tadpoles
    Apr 2016
    Cincinnati
    1
    We have had our AG pool 15+years in Ohio. I do leave a couple inches of water on the winter cover each year as it really helps the wind issue. Siphon and removing leaves/debris as needed to keep below skimmer. We have no issues with this method except for spring time frog/toad mating season which is complete by pool opening time.
    Any ideas on how to prevent this? (draining water is not an option) . Is it possible to treat the above cover water?
    Thanks for reading.
    Jun 2014
    15,153
    Re: Pool winter cover and tadpoles
    Hello and welcome to TFP! We have a strict "NO MATING" policy at our pool, and keep signs posted at all times to warn the critters. Well, even if we did, it doesn't help. I still get frogs out of our pool quite frequently. Clever little guys. Honestly, not sure of anything "chemically" you could do. Look at it as a compliment for your well-maintained pool.
    Maybe someone else will have a thought or two. In any case, we're happy you found us. Have a nice evening.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Walk out to the pool every other day and rake the top off? Put any eggs your find in a bowl and take them to a local pond?
    Kim
