Results 1 to 18 of 18
Thread: Sta- rite pump motor
    Apr 2016
    Atkinson nh
    2
    Any advice would help. I just opened my pool in NH. The motor is acting up, won't start some of the times, I have to hit the switch 4 or 5 times. Any suggestions on whether the motor should be replaced or rebuilt? The motor is a sta-rite 3hp model #p6e6h-209l thank you for any suggestions.
    24,000 gallon gunite pool with attached hot tub. Sta-rite filter 99 percent floor system. Heated thru house boiler (oil).
    Re: Sta- rite pump motor
    Why such a large pump? That's crazy big unless your pool is Olympic size.
    Support the site
    Apr 2016
    Sanibel, FL
    2
    Under the cap shown in the picture with the label is a start capacitor. A 3HP motor will draw a large current to get started. You may have to replace the capacitor as it would appear, without knowing more about the motor, that it is going bad. I would remove the capacitor and have it tested.
    Approximately 13,000 gallon pool; Gunnite construction; in-ground; built in 2003. NatureSoft Chlorine Generator, new circuit board, Revision 1.59 with a 3 month old Cell. Attached is a heat pump. Pump motor is the variable speed "ecotech EZ". Hayward 90 Ft2 pleated filter.
    Apr 2016
    Atkinson nh
    2
    Quote Originally Posted by JamesW View Post
    That's the way it was when we bought the house. What would be sufficient?
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    I'm friends with Barry and know about the pool too. It's a 20x40 free form gunite pool with floor cleaning system and separate spillover spa. There's a water feature (waterfall) and pond as well, but they are both on a different pump I believe, right Barry? The 3HP pump is about 40' from pool and probably about 18" above the pool. Not sure if those affect the size motor used. It is a beast though and I'm sure wastes a ton of electricity.
    I can help with removing the capacitor to have it checked, if that's what it sounds like. But where the heck do you get that testing done?
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Ok, we've taken a look at the capacitors. There are two. One for running most likely, and one for starting. How do you know for sure which is which? I'm assuming the larger one is for starting. Here's pictures of each, the black one is the one I think is the starting cap. We are getting more pictures of the silver one to see what the ratings on it are. I've never bought caps this large before, but I'm assuming the 189-225 MFD is the rating, and the 250VAC is the only other requirement.
    Something like this to replace the black one? Do brands matter?
    TEMCo Motor Start Capacitor SC0077 - 189-227 mfd 220-250 V VAC Volt uf Round HVAC AC Electric: Electric Fan Motors: Amazon.com: Industrial Scientific
    Jun 2008
    San Antonio, TX
    129
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    So looking for some pointers as Barry and I try to troubleshoot what is now a dead motor. He shut if off earlier today, and it would not turn back on at all. No clicking, humming, anything. He killed the power, swapped out the start cap, and still nothing. So whether the start cap was the issue or not is not clear, but the motor won't start. Any ideas? I plan on heading over and checking voltages and stuff at the motor connections first, but thought I'd throw this out there to see what others thing. The motor was running, and he shut it off to vacuum or something, and then it did not come back on when he tried to turn it back on. This is what we thought before, was the cap, as it would restart, but it would labor to do so a bit.
    Thanks.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,806
    Capacitor branding doesn't matter you need to match Voltage and MFD (micro Farad) rating. You may have a burned out coil in the motor based on the "its not even humming anymore". Try rotating the motor by hand about a quarter of a turn and try starting it again. That may get you going for a short time but the motor is sounding like it may be dead. Pull the rear cover off the motor and look for any burnt or broken wires/connections. Give it a sniff test with your nose to see if it smells burnt. Maybe start looking into a lower HP and possibly more energy efficient pump.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    The cap we bought to replace the one it had did match the existing one, to the T. I hope it's not the motor...
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,806
    Do you have access to a multi meter or a clamp on current probe?
    Chuck-
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    I have a nice digital multimeter, yes.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,806
    you can try and do resistance tests on the motor leads.
    Chuck-
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    I'll have to look up the procedure for that, as I've never done it. Thanks for the tip.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,806
    Here is a quick and dirty of the things you should check for. http://www.fluke.com/fluke/uses/comu...le-phasemotors
    Chuck-
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Wow, good stuff, thanks Cladamec.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Well, we ran some tests tonight. It was actually the first time I checked out the motor. And you know how they say to fist look for the low hanging fruit/obvious stuff? Well I did just that, by first checking the electrical connections. Both hot legs were loose. One was so loose it actually probably had a 1/16" gap between the connector and the post. I'm thinking that expansion and contraction was causing that lug to lose connection, and the motor wouldn't run. I tightened them all up and it fired right up (although it was running on it's own again when I got there). So I'm thinking intermittent loose connection. Should be good now, but time will tell for sure.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,806
    Easy, obvious, and fixed is always a good day. The wires can definitely loosen on their own over time, its not a bad idea once every couple of years to check the tightness on those screws.
    Chuck-
