Results 1 to 12 of 12
Thread: Door stop for outdoor fridge?
    Feb 2015
    California
    19
    So, we're now installing the fixtures in our ODK, and discovered something we had not anticipated...
    The fridge door swings to the right to open, towards the end of the island. If someone is not paying attention, the door could open up wide enough to thwack the outer stucco edge - which would dent the door of the fridge.
    Putting some sort of door stop in the deck seems like an invitation to trip over it...but we don't want a dented door in the first weekend of use.
    Has anyone else solved this issue? How did you handle it?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,539
    Re: Door stop for outdoor fridge?
    Quite a few fridge doors can be switched to the other side. See if your can. Look at the top of the door. If you see "stoppers" on then other end in the same place the hinge is then you can change it.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    How about something rubbery attached to the spot that would deliver the dent?
    Feb 2015
    California
    19
    Quote Originally Posted by kimkats View Post
    Kim
    Kim, that won't help - then we'll have two doors into one another, and the handle of the fridge would bash up the front of the doors under the BBQ.
    Quote Originally Posted by pooldv View Post
    That's what's most likely - a rubber-sheathed doorstop, drilled down into the deck. But it will also be a tripping hazard for me, since I never look where my feet are going.
    Anything mounted on the stucco island would probably deliver a dent as well, even if wrapped in rubber....
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Slap something on the door itself to keep it from denting.
    DFW, TX
    24,497
    Hey, how about a Jimmy Buffett magnet?
    The good news is that dented fridges still keep the beverages chilled!
    Apr 2010
    East Texas
    9,621
    Let's....NOT......be rude to Jimmy!
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    I bought some foam tubing at lowes - I think it was some kind of pipe insulation, cut it to the size of the fridge door and wedged it in between the door and the stone. It does the job and is not as ugly as it sounds! Lol
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    DFW, TX
    24,497
    Quote Originally Posted by woodyp View Post
    10-4
    Feb 2015
    California
    19
    Quote Originally Posted by Readyforapool View Post
    Hmm, good idea, thanks!
    We did buy the rubber stop that drills into the deck...But I like the idea of the foam, too.
    And for those thinking that dents are fine, or that we should cover up the SS fridge door...you're clearly not as OCD as my DH.
    Jun 2012
    western NY
    1,560
    Could you attach a small chain inside the fridg from the door to the inside, top of the box to keep it from going too far
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    May 2013
    Ontario, Canada
    63
    Can you add a piece to the top area instead of the ground tripping section? Place a small plastic garbage can / recycling bin in that spot?
    I am sure we could all get more creative with a picture or two.
    18' x 36' vinyl steel wall pool with deep end, 2 lights and 6' steps, main drain, SWG, Cartridge Filter, 320,000 BTU Rheem heater, 3/4HP 1 stage pump - Ontario, Canada
