Thread: Heater Plumbing PVC/CPVC - Black Couplings - Which Cement
    Jul 2013
    Phoenix, AZ
    67
    I am plumbing a Laars heater and they provide black plastic couplers/coupling nuts to connect the heater to the pool PVC plumbing. My question is what cement should I use to bond the Laars black plastic coupler to the PVC pool plumbing.
    Is the coupler ABS or something else.
    Is there a transition cement or should I use normal PVC cement.
    The Laars manual says nothing about the type of plastic that these couplers are made of.
    Thanks!
    Gary
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Re: Heater Plumbing PVC/CPVC - Black Couplings - Which Cement
    I would recommend giving them a call on Monday, just to be sure you're not missing anything for your warranty.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    The coupler is cpvc, it is more heat resistant than pvc. You can use Oatey red
    All Purpose Cement | Plastic Pipe Cements & Primers | Oatey
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would tend to agree with pooldv, all purpose red will work regardless if it is black PVC or black CPVC
    Jul 2013
    Phoenix, AZ
    67
    Thank you gentlemen. Have a great Sunday.
