Results 1 to 15 of 15
Thread: High TA help
    Jul 2015
    Ohio
    14
    High TA help
    Okay, it's our first opening of our pool and really first go at balancing since we pretty much closed it up after finishing install at end of season last year. Based on pool store calc our TA is at 180 and ph is 7.8. So, if I understand everything correctly we need to add muratic acid to lower the TA while not letting ph drop below 7.2, is that correct? Also, our chlorine level is at 0.5. Should I get TA lowered before I raise that level or do them at the same time? Help please?
    16x32 IG/vinyl liner steel wall, 1.5hp Hayward SuperPump VS, Hayward swimclear 325, 1 Hayward Colorlogic 4.0, automatic chlorinator.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: High TA help
    It's actually a multi step process that will need to be repeated until the TA is where you want it.
    Pool School - Lower Total Alkalinity
    Support the site
    Jul 2015
    Ohio
    14
    Re: High TA help
    Thank you, that link was very helpful. Just one question, should I attempt to raise chlorine level at same time or wait until it's balanced?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: High TA help
    I wouldn't do anything based on pool store results.
    Since you're just opening, low chlorine is a pretty safe bet, so add that to the appropriate level for your CYA. But even that CYA reading is suspect if the pool store tested it. Note: if you see "99" listed as the value, it means 100+.
    Do you have your own test kit? That's key to getting the water balanced as quickly and cheaply as possible. I've seen countless threads here over the years where the pool store says X is low, and the poster adds X and next week it is too high, or they didn't add anything and next week X is higher than the week before. It's an endless merry-go-round and ultimately, you pay for it.
    Jul 2015
    Ohio
    14
    Re: High TA help
    I was starting to feel like we were on that merry-go-round last week. Add decreaser, add increaser, repeat. What?? So I had sample retested at a different shop and vowed to buy my own kit today. Thank you, I am definitely taking that piece of advice and researching test kits as we speak.
    Jun 2014
    15,221
    Re: High TA help
    They get you every time.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Re: High TA help
    Definitely get a reliable test kit and use ONLY THOSE RESULTS to guide you.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    May 2014
    Franklin, NC
    9,193
    Re: High TA help
    Thanks Richard! I missed that it was a pool $tore test......
    This is the kit you want - TF-100 Tftestkits.net
    Support the site
    Jul 2015
    Ohio
    14
    Re: High TA help
    Okay, I think we are finally about there. TA is down to 160, Ph is at 7.6, and chl is at 2. Water is crystal clear ��. Now I have a new problem. These very tiny, almost like skin cells laying on top of water. You can barely see them until they catch the sun, but they are all over the surface of the water. What are these and how do I get rid of them? Have I mentioned how much I love this forum? It has been a life saver.
    Jun 2014
    15,221
    Re: High TA help
    Floating particles huh? Hard to tell. Could be a few things. Were you ever able to get one of the recommended test kits to post a full set of test results? That might help us.
    Jul 2015
    Ohio
    14
    Re: High TA help
    Sorry Texas, it has been a crazy week. No, I have not had the chance to get the kit yet. I know I need to make this a priority ASAP. In the meantime I have been using a combo of pool store analysis with cheap home test to compare results. Here are current results: ph 7.8, fc 3, ta 120, cya 50. Like I said, pool water is clear (except for the stupid worms I have to vacuum daily with all this rain) and you can barely see these clear flake things all over the surface.
    Jun 2014
    15,221
    Re: High TA help
    If we were to accept those numbers as accurate, I would recommend increasing your FC to about 5 based on your CYA of 50. Never let the FC drop below 4. Did you happen to get a CH test? It normally doesn't apply to vinyl pools, but in your case with floating particles it may not be a bad idea. Other than that ...........
    Jul 2015
    Ohio
    14
    Re: High TA help
    TH was tested (287) but not specifically CH. I guess based on what I have read here we can estimate CH at 189.
    Jul 2012
    Herndon, VA
    419
    Re: High TA help
    Could the clear flake things on the surface of the water simply be tree or grass pollen?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Jul 2015
    Ohio
    14
    Re: High TA help
    Could it be that simple? I would have thought my filter would clear this up, but no such luck. I ordered a sock for the skimmer, I will let you know if the problem keeps up.
