Results 1 to 7 of 7
Thread: Adding Solar Heater, Pump Motor size??
    May 2011
    Cincinnati, Ohio
    8
    Hello! I have a +-30,000 IG L shaped pool to which I am adding solar heating. I have 1 1/2 plumbing with 2 skimmers, drain and 5 returns. The heating pads are on a pergola 8 ft away from the pump and about 16' above the pump. I will be dry fitting and plumbing all but the actual connections to the system today.
    I currently have an AO Smith b228se 1HP motor that sounds like it is on its last leg. Do you guys think I should I replace it with a USQ1152 1 1/2HP SF 1.1 motor or just stick with the 1hp replacement USQ1102 ? Any advice would be much appreciated.
    18x40x26 IG True L shape | Jandy Ei SWG | Hayward SP2607x10 Pump| Century UST1102 1HP motor | Hayward S244T filter | SmartPool WWS601P Solar panels 2'x20' Quantity 6, clear solar blanket
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Adding Solar Heater, Pump Motor size??
    Welcome to TFP!!
    Can you do us a favor an add your city and state to your profile as it helps us deliver better answers to questions asked.
    Support the site
    30,419
    Welcome to the forum. Your info in your profile shows a JEP VS pump.......is that right?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have a similar setup using 11 4x12 Techno-Solis panels roof mounted at about the same height and a 1.5 HP Jandy Flo-Pro pump with a clean DE filter I get about 40 GPM through the panels according to my flow meter, which is a bit under the optimal 4.5 GPM per panel that are in the Techno-Solis specs. However I do have a Hayward Perflex style DE filter which seems to add more back-pressure than most other DE filters, however DE filters tend to add more back pressure than sand or cartridge filters. Hopefully this will give you a few data points to make a guess.
    Ike
    p.s. if you change motors you also need to change impellers if you want more performance out of the pump, just replacing a 1 HP motor with a 1.5 HP motor will just cause the motor to be oversized and output 1 HP of work.
    May 2011
    Cincinnati, Ohio
    8
    Sorry, I have no idea what that signature was. Updated now
    Quote Originally Posted by Isaac-1 View Post
    Ike
    Thanks Ike. What impeller would you recommend? SPX2610C or SPX2615C
    May 2011
    Cincinnati, Ohio
    8
    I am going to go ahead with the SPX2615C and the USQ1152 unless anyone sees an issue with it on the Hayward SP2607x10 Pump with SmartPool WWS601P Solar panels 4'x20' Quantity 3 about 8' away from the pump and 16' high.
    mas985's Avatar
    Pleasanton, CA
    11,737
    I run my two story (25') high solar with a 1/2 HP pump so at 16', there would be no issue running it on nearly any pump. I would just keep the impeller size you have now.
    Mark
