Thread: should I open
    May 2015
    Pleasant Gap Pa
    47
    should I open
    I just popped the corners of the pool cover and for the first time in forever my pool is clean and clear. I used TFPC method last year. Woohoo! But....my water temp is only 49 and I wonder if I'll get any kind of accurate readings on the chemicals with temps that low, maybe I should wait and open in a few weeks. Is there a way to get accurate chemical readings in water that cold?
    26700 gal IG vinyl lined pool. Clean and Clear 100 sq ft cartridge system, 1 hp Pentair SuperFlo pump
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    576
    Re: should I open
    If concerned about the temp of water when testing... Scoop it into a bottle and let it sit to room temperature then test
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: should I open
    If there's no more danger of freezing, open up now while the water is too cold to grow algae.
    The only test that is affected badly by cold water is the CYA test. Just set a sample jar in a sunny windowsill to warm up and test that one later. The rest you can do immediately. Be sure to let the water circulate a while before you grab a sample.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    Re: should I open
    As Richard points out, without circulation you are not going ot get usable test readings. It is very possible that you have a layer of rain water sitting on top of the pool water from closing that is not mixed.
    If it's clear now and there is no posibility of freeze, open her up. With cold water your chlorine demand will be minimal and you can probably get away with short pump run times until the water stars warming up.
    Support the site
    May 2015
    Pleasant Gap Pa
    47
    Re: should I open
    Thanks guys. My numbers right now are FC 1, CC 0, PH 7.0, TA 60, CYA 50. I'll pull the cover off this afternoon and get it running. So very nice to open a clean and clear pool!
