Results 1 to 7 of 7
Thread: Adding thru the Skimmer ??
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    Am I doing any damage to my pump by adding the Bleach and MA directly into the skimmer if I wait awhile before each one ? I know better not to mix the two together ever.
    6100 gal. In ground pool,1HP Pentair Superflo pump, 100 sq. ft. Cartridge filter , 3" tab dispenser, Aqua-Cal heat pump system ,Baracuda MX8 cleaner, in a Birdcage,Taylor K-2006 complete FAS-DPD chlorine kit.
    "Remember Folks Freedom Isn't FREE !!!"
    Donldson's Avatar
    NW Ohio
    2,881
    Re: Adding thru the Skimmer ??
    Don't do that. The bleach won't be good for it but will be relatively minor compared to the damage the MA will cause. Adding MA to your skimmer is a good way to destroy your heat pump, as well as damaging the plastic and rubber parts of your pump and filter.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    JoyfulNoise's Avatar
    May 2015
    13,173
    +1 ^^^^^^
    NEVER add MA directly to the skimmer!!
    Matt
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    I thought I read on here someone said it was ok to do if it is diluted. Since I only have to add such small amounts at a time I was hoping it would be diluted enough before it hits the pump/heater. I hope I havent caused any damage being lazy since my surgery. I better go back to the old bucket and walk around the pool spreading it I guess. Anybody have any tips on an easier way? I would appreciate it.
    Thanks Sgt
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by sgt173 View Post
    Thanks Sgt
    You might be thinking of this thread. Need A Clorox Bottle Holder - Calling All PVC Engineers
    Adding to the skimmer is far from ideal, but if you're incapable of squatting down, say you're wheelchair-bound, then you do what you must. But it is better to add to the pool than to the skimmer.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Here is a handy page on chemicals and how to add them, Pool School - Recommended Pool Chemicals
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    All ya, gotta do is pour them slowly in front of a return with the pump running. Scratch walking around the pool.
