Thread: Motor is sparking when turned on.
    Oct 2007
    spartanburg, sc
    20
    Above ground 12,500 gallon pool.
    Hayward Power-flo LX Pump, had maybe 10 years.
    This season, when I turn on, a few sparks fall out from where the ground wire is attached (I think), the motor and pump turn on anyway and work fine. I did this a couple of times. This morning, I video taped it because I was going to ask a local small motor repair shop about it. Only this morning I turned it on, it sparked, then the motor stopped and it will not turn on. I think I probably blew it.
    Here' the quick youtube video:
    Hayward Pool Pump Sparks - YouTube
    Anyone have any suggestions? Probably just buy the pump unit again, I think it's around $250
    Jul 2015
    Central Valley CA
    1,109
    Re: Motor is sparking when turned on.
    yup it's dead.
    If it is any consolation based on the sound there may not have been much you could have done might have just been the brushes but based on the age I would guess the internal parts were worn and I don't think just doing the brushes would have kept it going for long. You could just replace the motor but I think a whole new pump might be a good idea again just because of age. since you have to replace might want to think about a 2 speed they can usually pay for themselves in 2 - 3 years
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jun 2012
    western NY
    1,562
    The sparks may have come from a loose connection at the back of the motor. If that is the case, disconnect the power and clean and tighten them. Once that is done look for a GFCI receptacle or breaker that controls the circuit and reset it. It is most likely that you tripped a circuit breaker or GFCI when it was sparking.
    Edit,... I just watched the video. That motor may be shot or it could be loose connections, Hard to say. Do you want the list of code violations I saw in that video?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Pull the pump apart and either have the motor rebuilt or replaced. You won't even have to disturb the plumbing. It looks like you just unplug it and undo 4 bolts and the pump/plate/impeller all comes off. When my motor died I just took that whole mess to the pool store and let them deal with the impeller bolt and the seal. I had it back in a couple hours, although it was the off-season.
    If the pump will be down for more than a day, you should take your FC level up to shock level and brush well to get it all mixed so you don't develop algae.
    Oct 2007
    spartanburg, sc
    20
    fixed it. Pulled the back off and there was an exposed wire. stripped it, crimped a new attachment to it and plugged it back on the receiver - works fine.
