Results 1 to 8 of 8
Thread: Gauge stuck
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    Gauge stuck
    When my pump is off, the gauge reads 10psi. Turning on the pump and the pressure raises to 25psi.
    Should I replace the gauge or just go with it for the season?
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Gauge stuck
    You should replace it. You never know when its gonna permenently stick.
    They aren't expensive at all.
    I recommend the gauge which is sold on TFtetkits.net websitesite. It glycerine filled and very well built. None of that cheap plastic stuff. The scale on the gauge is much more defined to. Its only about 12 or 13 dollars.
    I have one and absolutely love it.
    Divin Dave,
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Gauge stuck
    I agree you should replace it with a quality gauge, the ones the pool companies sell are bottom of the line junk, very inaccurate and prone to failure.
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    Re: Gauge stuck
    I did buy one here last year to replace the one that came with the filter.
    Expected it to last more than one year!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: Gauge stuck
    Could you post a pic of it? There might be something that the folks here can spot.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Gauge stuck
    If it is a new quality gauge you may want to unscrew it and see if the stem is clogged
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    Re: Gauge stuck
    Isaac, I will give that a try.
    I have uploaded photos with the pump on and off if anybody cares to take a look!
    http://imgur.com/a/Ft3Fc
    30,424
    Re: Gauge stuck
    Did you get that gauge from TFTestkits? PM me if you did and we'll take care of you.
