Thread: Solar - Distance from pool
    Nov 2014
    Australia
    78
    Hi, I'm just about to take down my little 10,000 litre Intex above ground pool. Next summer, I'm getting a 6mt x 2.5mtr inground pool which is going to be sunk in about half way. We're trying to decide whether to leave it in the same place as now which would mean cheaper fencing. It is in the sun most of the day in summer but in the spring and autumn, it won't get much sun as there are trees that will shade it. The shade is fine in the summer - we can get up to 40deg C days, so the shade is very welcome.
    I want to extend my swimming season for a few months either side of our summer, which means, I'll be able to start swimming in September and close up in May. My question is, if we install a solar heating system, how far away can it be to be effective? If I leave the pool where it is, then the distance to our sheds and garage roof would be about 15 to 20 metres (depending on the route through the garden. Is this too far way from the pool to be effective? I'm thinking of the heat loss although I would probably bury the pipes in the ground.
    2014 to 2015m pool 10000 litre (2531 Gallons) Bestway Above Ground Pool 412cmx201cmx122cm (162"x72"x48"), 1000GPH Sand Filter Pump System
    2016 New Pool - 3mtrx5.6mtr 20,000 litre Oval Above Ground, 21" Ongar Sand filter with 550 watt pump. (being sunk 60cm inground)
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Solar - Distance from pool
    The shorter the better is a simple answer, you can also insulate the plumbing runs with something like expanding urethane foam which will help.
    Apr 2013
    Sacramento, CA
    2,769
    At that distance the heat loss would be negligible. Solar systems don't have high heat so they lose less.
    Apr 2015
    Brookline
    60
    Mine leaves the pump pad, travels 100ft to the house and 35 ft up then 100 ft to pad and 15 to the pool. Works great
    Southern New Hampshire, 18x36 single roman end pool.
    Nov 2014
    Australia
    78
    Thank you, that makes it easier to leave it where it is - which makes it better for the whole look of the garden.
