Thread: New Pool / New to Algae
    Sep 2015
    Roseville, Ca
    16
    I had my pool running since February, never been in it. Go away for 3 weeks in April, put solar
    cover on it for first time while I was gone. Came home to dull water and green spots.
    I have filter running, brushed sides and taken cover off.
    2 questions
    1) how do I address the algae and get rid if it?
    2) Did the bubble solar cover affect the PH while I was gone.
    Pool is on auto timer.
    currently; PH - 9 / ALK 180
    THANKS FOR YOUR HELP
    Tom
    TomCa - IG, gunite, Freeform, 30 x 17, raised beam wall w/ledgestone and flagstone cap, 3ft spill, radiant fusion blue frost, 480sqft concrete decking. SWG filtration, 2 returns, 1 skimmer. 2" & 2.5"PVC . JEP15 Jandy ePump 1.5hp Variable Speed, AquaLink PDA P4 Pool Control , SAVI-MELODY100-J Nexxus 14W 12V Pool Light X 2, J Series, Polaris - 360 Cleaner, Model F1B.
    Aug 2014
    Northern IL
    4,615
    Re: New Pool / New to Algae
    Please get your pH down asap using muriatic acid from any hardware store. Then post back. Please also tell us how you are testing the water and if you have a recommended testkit: Pool School - Test Kits Compared , we can help you from there.
    klynch494's Avatar
    Aug 2015
    Twin Cities/MN
    96
    My first question is...while you were gone the 3 weeks, was someone testing your levels and making the necessary additions to keep the chemistry in balance? If so, the answer to number 2 would be, not likely.
    To answer question 1.... sounds like performing a SLAM might be in your future.
    http://www.troublefreepool.com/showthread.php?t=3913
    Are you testing the pool yourself? It would be helpful to post your results so we can get a better idea of what you're dealing with.
    ~Kevin (MN)
    13.5k gal, 24' Round AG Vinyl
    2HP Waterway Pump, 200sqft Hayward Element Filter
    BBB Method & AuquaSmarte Inline Chlorinator, TF-100 Test Kit
    Kevin, TFP Believer & Supporter
    (Yup, I drank the pool water)
    13.5K gal, 24' Round AG Vinyl, TF-100 Test Kit
    2HP Waterway Pump, 200 SqFt Hayward Element Filter
    Recommendations: Pool School, TFTestkits & Pool Math
    Sep 2015
    Roseville, Ca
    16
    I will do as u suggest.
    How do I know if it is salt problem?
    I have a SWG and wonder if I have enough salt in the pool ?
    Thanks
    Tom
    Jun 2014
    15,138
    Most SWG owners will test their own salt levels, even though many SWGs have some type of indicator to let you know if the salt is low. In any case, your first order of business will be to remove algae, and to do that you require a SLAM (link below). During the SLAM, you can leave the SWG off and rely solely on regular liquid bleach to maintain the required FC level.
    Most importantly Tom, you'll need your own test kit (TF-100 w/ XL Option or Taylor K-2006C) - TF-100 link below. With either kit, I highly encourage you to request a "Speed Stir" as well to make mixing and testing so much easier. It makes a world of difference. Oh, and the TF-100 link also has salt test kits/strips as well. Read the SLAM page and let us know if you have any questions okay.
