Thread: 2 HP impeller in a 1 1/2 HP wet end
    Apr 2016
    port st lucie
    1
    I have a 1 1/2 HP pump and wet end Emmerson pump center discharge (Bad pump and impeller, wet end still good). I got a replacement 2 HP pump and wet end side discharge. Can I reuse the 1 1\2 HP center discharge wet end and the 2 HP impeller on the replacement pump.
    So the ending setup would be:
    2 HP pump
    1 1/2 HP Wet end
    2 HP impeller
    Will there be an issue with this setup?
    Sep 2013
    Charleston, SC
    537
    Re: 2 HP impeller in a 1 1/2 HP wet end
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    38,235
    When you say pump do you mean motor? I would leave the one and a half horsepower impeller on the two horsepower motor just to save money on electricity.
    Apr 2016
    Toms River
    7
    I'm not a professional, but I thought the impellers were sized for the HP in many of those wet ends?
    2016 Artesian Pelican Bay
    38,235
    Most wet-ends are the same for all the motor/impeller sizes; although I think there are a few designs that do have a different diffuser for some of the impeller sizes (I am not sure which ones).
    Just need to make sure that the rating of the impeller is less than or equal to the motor SFHP rating.
