Thread: Balancing pool after Slam
    Sep 2015
    Columbus IN
    52
    I was done slaming the pool a couple days ago so now getting pool balanced.
    FC 6
    CC 0
    PH 7.5
    TA 80
    CYA 50
    CH 500
    As you see I have high calcium hardness. My CSI is 0.09. I have lost 2 ppm FC a day since the Slam.
    Would like any comments on how I am doing.
    15000 gal, IN, Hayward Super Pump VS, Hayward Heat Pro Titanium heat pump model number HP2110T, vinyl, Dolphin Apollo.
    Hayward sand filter model number S210T, TF-100 test kit with speed stir. It was built in 2012.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Balancing pool after Slam
    Enjoy!
    Your readings look fine. Your CSI is nowhere near the danger zone, so don't sweat the high CH.
    Sep 2015
    Columbus IN
    52
    We will enjoy it.
    Thanks
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Nice numbers!
