Thread: Ok now this is just getting biring
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Where is the challenge in opening a pool previously treated the right way with the TFP method.
    I opened yesterday and for the cost of two bottles of bleach, this is my pool today. Second year in a row! Didn't even need stabilizer. Was still at 70!
    Thank you TFP!
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Aug 2014
    Northern IL
    4,615
    Re: Ok now this is just getting biring
    Are you sure there's water in that pool? Congrats on being bored!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    Steve! I bet we could read the heads/tails of a dime in the far picture! lol
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Don't worry, the Springtime Opening rush is about to begin here. You can fill your free hours answering questions. You know how it works.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Right! I got complacent with testing last year and had to do a little mini-SLAM. But, even that was easy and we kept right on swimming.
    Yep, jump in there and help some newbies!
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    TFP is just so great. Some others will listen and get the same results and others don't and still add tons of junk that aren't needed.
