Thread: Good news after 12-20 inch rains re pool
    Houston, TX
    1,101
    Hello to all,
    After a good over-flow of mulch and garden soil run-off into the pool, she's as clear as can be and has been since Wed after the Monday Houston rains. We ended up w a total of 16", and 5-6" from 415AM - 6AM that morning.
    My CYA was 40-45, so I brought the FC to 20 and the pH to 7.2-7.3 What's been great that is w all the rains and aeration, including the spa spillover and scuppers, my pH has only risen to 7.4 [above 7.2 but below 7.5]. I think my TA and pH are now in equilibrium, HOW COOL. I have not had to add any acid since I did so on Monday. I have also not added any CL either. I am still above FC = 5+. I'll do so more testing tomorrow, but the water looks great and w all the rains, I have nicely lowered my CH too. I have 6 gallons of 8.25% CL in the garage so I'm set for the next month+. I'll make sure it stays cool.
    Thanks again for everyone's help and support...check for donation/support on the way....regards, tstex
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    Jun 2014
    15,150
    Re: Good news after 12-20 inch rains re pool
    Nice! Plenty of sunshine today as well to warm-up our water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    You're a fine testimony to how easy it is to deal with a problem when you're armed with a test kit and some knowledge. I imagine the Houston pool stores are doing a bang-up business right now in floc and clarifier and "shock."
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Nice work! Thanks for supporting TFP!
    Houston, TX
    1,101
    Thank you guys. The more I read posts, do my own testing and then research it, then the info and dynamics of it start to stick...pat, our water temp is still in the low 70's, but we went in yesterday and those of us that were not fully awake, were fully awakened...but, pretty refreshing.
